vtrx
Format text on the OLED display |
Posted: Fri Jul 24, 2020 4:19 pm |
I have an OLED display model SSD1306.
I have a function that shows the temperature in this format;
Code: | signed int16 chip_temp;
chip_temp = Get_Temperature (); |
The routine for displaying on the LCD is;
Code: | SSD1306_DrawText (4,4, "123", 1);//x,y,Text,size |
Using a regular LCD, I use this routine;
Code: | printf (LCD_Print, "Temp:% 02Lu.% 02Lu C", abs (chip_temp) / 100, abs (chip_temp)% 100); |
How can I adapt to the OLED routine? |
Posted: Fri Jul 24, 2020 5:46 pm |
How about this:
sprintf it to a buffer, then give the buffer to the SSD1306_Drawtext() routine.
Here is the output of the program shown below, in the MPLAB v8.92 output window:
Test program:
#include <18F46K22.h>
#fuses NOWDT
#use delay(internal=4M)
#use rs232(UART1, baud=9600, ERRORS)
// Substitute function for testing with MPLAB v8.92 simulator.
// This function displays text in the UART1 output window.
void SSD1306_Drawtext(int8 x, int8 y, char *text, int8 size)
puts(text);
signed int16 chip_temp = 1000;
int8 buffer[20];
sprintf(buffer, "Temp: %02Ld.%02Ld C", abs(chip_temp) / 100, abs(chip_temp)% 100);
SSD1306_DrawText (4, 4, buffer, 1);
while(TRUE);
vtrx
Posted: Sun Jul 26, 2020 2:53 pm |
PCM programmer wrote: | How about this:
Test program:
#fuses NOWDT
puts(text);
int8 buffer[20];
while(TRUE);
worked perfectly. |
