bme 280 problem? HOW CAN I READ TEMP OR PRESSURE VALUE?
Goto page 1, 2  Next
akay
PostPosted: Mon Nov 02, 2020 4:33 pm     Reply with quote
I wrote a simple code to read temperature with bme280 sensor .. but it couldnt work? please somebody help me about that..
#define LCD_RS_PIN      PIN_B1
#define LCD_RW_PIN      PIN_B2
#define LCD_ENABLE_PIN  PIN_B3
#define LCD_DATA4       PIN_B4
#define LCD_DATA5       PIN_B5
#define LCD_DATA6       PIN_B6
#define LCD_DATA7       PIN_B7
#include <16F877a.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NODEBUG
#define use_portb_lcd TRUE
#use delay(clock = 8000000)
//24volt/<LCD.C>k istenilen en yüksek voltaj deðeri/ gerilim bölücüden çýkan voltaj
#include <lcd.c>
#include <BMe280.c>
#use i2c(master, sda=PIN_c4, scl=PIN_c3)
signed int32 pTemp;
  lcd_init();
  bme280_init();
  DELAY_MS(25);
bme280_get_temperature(pTemp);
lcd_gotoxy(1,2);
printf(lcd_putc," %d" pTemp);
delay_ms(20);
LIBRARY CODE
////                             bme280.c                              ////
//// Driver for Bosch BME280 Environmental sensor.  This sensor can    ////
//// read temperature, pressure and humidity.  This driver returns     ////
//// calibrated/compensated values by using the trim values on the     ////
//// sensor.  At this time this driver only supports I2C mode, it      ////
//// doesn't support SPI mode.                                         ////
//// API                                                               ////
//// ok = bme280_get_temperature(signed int32 *pTemp)                  ////
//// ok = bme280_get_pressure(signed int32 *pTemp,                     ////
////                    unsigned int32 *pPress)                        ////
//// ok = bme280_get_humidity(signed int32 *pTemp,                     ////
////                    unsigned int32 *pPress, unsigned int32 *pHum)  ////
Library code removed.
Reason: CCS forum rule #10:
10. Don't post the CCS example code or drivers, or ask for such code and drivers.
Forum rules: http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
PostPosted: Mon Nov 02, 2020 5:01 pm     Reply with quote
Notice that the definition of the function shows that you must pass it
a pointer to a signed int32.
That means you pass it the address of the int32.
Do it like this:
bme280_get_temperature(&pTemp);
akay
PostPosted: Mon Nov 02, 2020 5:14 pm     Reply with quote
Do it like this:
i dont understand what did you mean? by the way when i write this code "printf(lcd_putc," %d" pTemp);" i received this warning "Print format type invalid" but i use signed int? why am i getting this warning? could you please edit this code?
PostPosted: Mon Nov 02, 2020 5:38 pm     Reply with quote
You need to read about using pointers in the C language.
Use Google to search for articles on this.
Read the CCS manual for printf. If you want to print signed numbers
larger than int8, you need to use "%ld". Put the letter 'L' in front of the 'd'.
PostPosted: Mon Nov 02, 2020 6:16 pm     Reply with quote
You could easily have a basic hardware problem...
That PIC is designed to run on 5 volts, the BME280 sensor only 3 volts (most peripherals are 3 volts these days). You do need 'logic level conversion' to allow the PIC to control/receieve data from the device. If you bought a 'module' PCB that has the 'sensor', it might have the LLC parts on it. The datasheet should say ....
As it is an I2C device, download PCMPs I2C scanner program, located in the 'code library' here.
Run it to confirm the PIC can 'see' the BME280 device. If found, it's device address will be sent to the PC.
You should always run the 'scanner' program for every I2C device.
Jay
PostPosted: Tue Nov 03, 2020 1:11 am     Reply with quote
This "Print format type invalid" is because pTemp, is an int32.
Your printf, uses %d. %d is for a standard length integer. To print a
'long' integer, it needs %ld. Note the 'l'.....
akay
PostPosted: Tue Nov 03, 2020 8:54 am     Reply with quote
Jay
but still i can't read any value in the function.. the function gives error.. can u fix it?
PostPosted: Tue Nov 03, 2020 11:41 am     Reply with quote
Post your printf line of code.
PostPosted: Tue Nov 03, 2020 1:05 pm     Reply with quote
You would normally want the #use I2c line, befire you load the bme
code.
PostPosted: Tue Nov 03, 2020 1:37 pm     Reply with quote
The bme280.c driver has it's own #use i2c() line in it. The line posted
by akay is not needed. At least, this is true for the bme driver supplied
with CCS vs. 5.096.
But there's another problem I didn't mention before. If I compile akay's
program with CCS vs. 5.096 for the 16F877A that he is using, I get this error:
*** Error 71 "C:\...\Projects\PCM_Test\pcm_test.c" Line 37(1,2): Out of ROM, A segment or the program is too large bme280_get_temperature
Seg 00004-007FF, 0303 left, need 00AE5
Seg 00800-00FFF, 0800 left, need 00AE5
Seg 01000-017FF, 0800 left, need 00AE5
Seg 01800-01FFF, 0800 left, need 00AE5
Seg 00000-00003, 0000 left, need 00AE5 Reserved
1 Errors, 0 Warnings.
Build Failed.
Maybe he's using some earlier version of the compiler.
PostPosted: Wed Nov 04, 2020 12:56 am     Reply with quote
So basically the code is too big for his chip... Sad
jaka
PostPosted: Wed Nov 04, 2020 2:38 am     Reply with quote
I have used the bme280.c driver with PIC16F chips. The problem can come from the memory segment sizes, and not from the total ROM size.
Usually it helps to add #separate directives to the bme280.c before the functions
static signed int32 _bme280_compensate_T_int32(signed int32 adc_T)
static unsigned int32 _bme280_compensate_P_int32(signed int32 adc_P)
static unsigned int32 _bme280_compensate_H_int32(signed int32 adc_H)
However, I have been using the enhanced core 16F1xxx chips so perhaps this doesn't help with the 16F877A.
I can also provide a .diff patch file for the bme280.c which I have succesfully used with PIC16F1xxx and recent compiler versions. I can post it here if you think it doesn't violate forum rules (it doesn't reveal too many lines of the original code).
akay
PostPosted: Wed Nov 04, 2020 7:17 am     Reply with quote
i get this error too.. i m using 5.076 version.. i didnt compile with 16f877a ..i also have the same problem with the bmp180 driver. i am giving up..
akay
PostPosted: Wed Nov 04, 2020 7:30 am     Reply with quote
i'd like to say that when I try with other drivers, i dont see these mistakes.. for example Bmp085 and bmp180 drivers are almost the same.. i was working with bmp085 driver before the bmp180 driver came to ccs and it worked very well.. there's an another problem i don't understand..
that s my simple code
#include <lcd.c>
#include <BMp180.c>
int16 Temp;
int16 press;
int16 alt;
  lcd_init();
  bmp180_init() ;
  DELAY_MS(25);
bmp180_read(BMP180_MODE_STANDARD, press, temp, alt)    ;
lcd_gotoxy(1,2);
printf(lcd_putc," %d" press);
delay_ms(20);
and these mistakes
>>> Unsigned variable is never less then zero (in the driver code mistake)
>>> Condition always false
*** Error 114 "bmp180example.c" line38(23,28): Print format type is invalid::
////                   BMP180 BAROMETER DRIVER                         ////
//// Driver for Bosch BMP180 digital pressure sensor.                  ////
//// bmp180_init()                                                     ////
////     Initiliazes driver to communicate with sensor.                ////
//// bmp180_read(mode, *pressure, *temp, *alt)                         ////
////     Reads sensor values and saves them to the *pressure, *temp    ////
////     and *alt pointers.  'mode' is the resolution mode, see        ////
////     bmp180_mode_t for a list of valid values. *temp is read in    ////
////     degrees C, *pressure is read in Pascals (Pa), and *alt is     ////
////     calculated in meters (m).                                     ////
//// BMP180_NO_ALTITUDE                                                ////
////     If #defined, the bmp180_updateValues() function will not      ////
////     read and populate the pressure value.  This is useful for     ////
////     devices with small memory footprint that cannot fit the       ////
////     math required.
typedef enum
BMP180_MODE_LOW_POWER = 0,
BMP180_MODE_STANDARD = 1,
BMP180_MODE_HIGH_RESOLUTION = 2,
BMP180_MODE_ULTRA_HIGH_RESOLUTION = 3
} bmp180_mode_t;
void bmp180_read(bmp180_mode_t mode, signed int32 *pPressure,
                         signed int32 *pTemperature, signed int32 *pAltitude)
   union
      unsigned int8 b[4];
      unsigned int16 w[2];
      signed int32 dw;
   } scr32;
   signed int32 rawTemp=0;
   signed int32 pressure=0;
   if (pTemperature)
      //WRITE 0X2E INTO REG 0XF4,WAIT 4.5MS
      bmp180_write(BMP180_REG_MEASURE_CTL,BMP180_VAL_TEMP_CTL);
      delay_us(4500);
      //READ REG 0XF6 AND 0XF7
      rawTemp=bmp180_read16(BMP180_REG_MSB);
      *pTemperature = bmp180_calculateTemperature(rawTemp);
Crying or Very sad Crying or Very sad Crying or Very sad
PostPosted: Wed Nov 04, 2020 8:51 am     Reply with quote
I told you how to fix the printf format type error in this post.
You ignored my advice.
http://www.ccsinfo.com/forum/viewtopic.php?t=59035&start=3
The 2nd problem with the printf line is that you have left off the comma
after the "%d". You have to read the CCS manual and do what it says.
The correct line is like this:
printf(lcd_putc," %ld", press);
Regarding your errors with this other driver:
Post a link to the website where you got the driver.
Goto page 1, 2  Next
Page 1 of 2
