cvargcal
error compiler with symbol "_" |
Posted: Sat Apr 18, 2020 10:46 am |
Hi, I try make portable a code from mplabx, but i get error with the simbol "_"
why?
for example
Code: | uint8_t* AddStringToBuf(uint8_t *_buf, char *_string)
uint16_t _length = strlen(_string);
_buf[0] = _length >> 8;
_buf[1] = _length & 0xFF;
_buf+=2;
strncpy((char *)_buf, _string, _length);
return _buf + _length;
this operation strlen(_string) make error if i write the varible with _
So some variable i shoud be declare without "_"
Code: | uint8_t* AddStringToBuf(uint8_t *_buf, char *string)
uint16_t _length = strlen(string);
_buf+=2;
strncpy((char *)_buf, string, _length);
The code work fine... but to end i have rename the variables.
maybe its stupid, but i want know why happen this.
Thanks |
Joined: 01 Jul 2010 Posts: 9168 Location: Greensville,Ontario
Posted: Sat Apr 18, 2020 11:02 am |
might be a 'C' syntax that variables MUST begin with a LETTER.....
CCS C mostly follows K&R C, though I've never been formally taught any C....
the pros here WILL know....
To me using an 'underscroe' character is bad...too hard to see on a screen using my 67 year old eyeballs.... |
Posted: Sat Apr 18, 2020 11:23 am |
C has restrictions on the use of _.
Quote: |
predefined macro names shall begin with a leading underscore followed by an uppercase letter or a second underscore.”
By avoiding leading underscores in your identifiers, you avoid the possibility of your identifier conflicting with a predefined symbol defined by the compiler implementation. Depending on the context, conflicts like this can be difficult to diagnose, so completely avoiding the possibility of a conflict is a good practice.
Coding standards and/or style guides within an organization will often prohibit leading underscores (to avoid the conflicts discussed above), and sometimes establish a naming convention for various types of identifiers, including whether or not to use underscores to separate words.
Because CCS by default does not use case, you have to avoid _ as the
leading character. |
Posted: Sat Apr 18, 2020 12:10 pm |
temtronic, remember that K&R pdf I showed you how to get the other day ?
It's in there. Search for the word: underscore
See section: 2.1 Variable Names |
cvargcal
Posted: Sat Apr 18, 2020 12:15 pm |
I like this answers...
Thanks you! |
jeremiah
Posted: Sat Apr 18, 2020 1:07 pm |
7.1.3 of the standard also has:
Quote: |
— All identifiers that begin with an underscore and either an uppercase letter or another underscore are always reserved for any use.
— All identifiers that begin with an underscore are always reserved for use as identifiers with file scope in both the ordinary and tag name spaces.
So as Ttelmah alluded to, using the _ at the beginning of an identifier (macro, variable, function, etc.) is technically "undefined", as defined in the standard:
Quote: |
If the program declares or defines an identifier in a context in which it is reserved (other than as allowed by 7.1.4), or defines a reserved identifier as a macro name, the behavior is undefined.
Posted: Sat Apr 18, 2020 3:13 pm |
heck, I downloaded it, got to read about 3 pages, then everyone wanted THEIR stuff done....I did run the plow through the 1/2 ac garden once, hauled a 70' black walnut tree home in pieces, lots of pieces.Only 3 pieces left, easch about 3200# and at top of steep hill....sigh.
full 16 hr days are getting 'challenging', at 67 I get tired for some silly reason. |
