RENNICK
Joined: 06 Apr 2020 Posts: 1 Location: TEC. INSTRUMENTISTA
Stack overflow 16F883 |
Posted: Thu Apr 09, 2020 6:47 pm |
Good evening. I made a program of a decreasing clock since I need it in ccs compiler. It is a subroutine of another main one. It works until when it has to repeat the cycle it starts presenting error of [PIC16 CORE] PC = 0x03E8. Stack underflow executing RETURN instruction. [U1], if you have any ideas to correct this error, I would appreciate it.
#include <16f883.h>
#fuses xt, nowdt
#use delay (Clock=4Mhz)
#define LCD_DATA_PORT getenv("SFR:PORTC")
#define LCD_ENABLE_PIN PIN_A0
#define LCD_RS_PIN PIN_A2
#define LCD_RW_PIN PIN_A1
#include <lcd.c>
#use standard_io(c)
int16 desbordamiento=0;
int s=0;
int m=0;
int c=0;
void pausa(void)
lcd_gotoxy(1,2);
lcd_putc("TIEMPO RESTATNTE: pausa\n");
while(input(pin_b0)==0){ // pulsa tecla stop se retorna
if(input(pin_b6)==1){ //pulsa la tecla play retorna y sigue decrementando
do{
while(input(pin_b6)==1);
c=0;
return;
void configuracion(void) //:::::::::: Función de Configuración ::::::::::
enable_interrupts(int_ext); //Habilitamos la interrupción externa
ext_int_edge(l_to_h); // se habilita la interrupcion ext. de bajo a alto
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256); //Preescaler 256 Timer0
set_timer0(224); //Establecemos el timer0 a 224 para obtener 10ms
enable_interrupts(int_timer0); //Habilitamos la interrupción del timer0
enable_interrupts(global); //Habilitamos todas las interrupciones del PIC
void inicio(void) //Función Aplicacion de señal MENU RUN::::::::::
configuracion();
lcd_putc('\f');
lcd_gotoxy(1,1);
lcd_putc("Aplic. \n");
lcd_gotoxy(28,1);
lcd_putc("% 00\n");
lcd_gotoxy(1,2);
lcd_putc("TIEMPO RESTATNTE: \n");
while (TRUE)
lcd_gotoxy(26,2);
printf(lcd_putc,"(%02u:%02u)",m,s);
void tiempo()
lcd_putc('\f');
lcd_gotoxy(8,1);
lcd_putc("*** MENU DE TIEMPO ***\n");
lcd_gotoxy(1,2);
while(true){
lcd_gotoxy(26,2);
delay_ms(200);
lcd_gotoxy(26,2);
printf(lcd_putc,"( :%02u)",s);
delay_ms(200);
return;
lcd_init();
enable_interrupts(int_rb);
delay_ms(300);
while(true)
lcd_gotoxy(4,1);
lcd_putc("\f menu main \n");
delay_ms(1500);
tiempo();
#int_timer0
void timer_reloj(void) //Función de Interrupción Timer,RELOJ:::::::::
desbordamiento++;
if(desbordamiento==10) // es 100 para 1 seg, pero se coloca 10 para hacerlo dinamico en la simulacion
desbordamiento=0;
if(s!=0){
s--;
if(m==0&&s==0)
m=0;
s=0;
disable_interrupts(int_timer0);
clear_interrupt(int_timer1);
clear_interrupt(int_rb);
clear_interrupt(int_ext);
main();
if(s==0)
s=59;
if(m!=0){
s=59;
m--;
set_timer0(224); //se carga el timer0 de nuevo para 10 mseg
#int_RB
ext_isr(){
if(input(pin_b4)==1){
do {
while(input(pin_b4)==1);
m=m+1;
if(m==60){
m=60;
if(input(pin_b5)==1){
do {
while(input(pin_b5)==1);
if(m!=0){
m=m-1;
if(input(pin_b6)!=0){
do {
while(input(pin_b6)!=0);
if(c==1){
pausa();
c++;
inicio();
if((input(pin_b0)==1)||(input(pin_b7)==1))
do {
while((input(pin_b0)==1)||(input(pin_b7)==1));
s=0;
m=0;
main();
_________________ I DEDICATE TO INSTRUMENTATION A BRANCH OF ELECTRICITY THAT IS IN CHARGE OF PROCESS CONTROL |
Posted: Thu Apr 09, 2020 8:10 pm |
Your program has a lot of coding bugs.
But the bug that's causing your stack problem is this one:
main();
You should not call main() in CCS. If you want to restart the program at
main() in CCS, you can make a outer while() loop. Example:
Quote: |
lcd_init();
delay_ms(300);
while(true)
lcd_gotoxy(4,1);
delay_ms(1500);
tiempo();
Or another option is to call reset_cpu(). Example:
s=0;
m=0;
reset_cpu();
Normally, this method of programming is not done. But it will restart
the program. |
