help for function extract string
cvargcal
PostPosted: Tue Mar 31, 2020 12:22 pm     Reply with quote
Hi, I have these strings:
+CBC: <bcs>, <bcl>,<voltage>
+CSQ: <rssi>,<ber>
Using strtok I can separate by "," but i get one array where i need clean.
So i search a function for extract "+CBC: " and "+CSQ: ", but the idea is it can work for any "header" like "ABCD: " or "12346786A: "
This for can get bcs and rssi or any data just after ": " from clean way.
My code
     char string[50], *ptr;
     char delimitador[]=": ,\r";                 // Token
     CHECK_VOLT();                              // AT+CBC
     strcpy(string,Receive_String_uart2);       // +CBC: #,###,####   +CBC: <bcs>, <bcl>,<voltage>
     ptr = strtok(string, delimitador);         //
     i=0;                                       //
     while(ptr != NULL){                        //
          if(*ptr != '\n'){                     //
            strcpy(&dat_batt[i][0],ptr);        //
            i++;                                //
            ptr = strtok(NULL,delimitador);     //
out:
+CBC: bcs
bcl
voltage
So after i need get bcs, or any data without "header".
I don't want to make manual way like this:
//! ------ CSQ----
        if (CHECK_SNG()) {   // CSQ: ##,##   +CSQ: <rssi>,<ber>
           n=0;i=0;                                            //
           for(i=0;i<5;i++){                                   //
              SGN[i]=Receive_String_uart2[n+15]; n++;
dluu13
PostPosted: Tue Mar 31, 2020 2:08 pm     Reply with quote
I'm not sure if I understand you completely, but you can use a function such as strstr() to find if your string contains CBC or CSQ. You can use strchr() to find the first occurrence of ':' and then set your string to the address of the character after ':'
When I was searching for stuff in my RS232 communications I used this page a lot:
http://www.cplusplus.com/reference/cstring/
cvargcal
PostPosted: Tue Mar 31, 2020 3:06 pm     Reply with quote
thanks you, yes that can be a way... I will study it.
EDIT
one solution like say dluu13, but i want find the way to search with "custom" header and not with char
int main ()
  int i;
  char str[] = "+CBC: 145frfrfrrfrhy";
  char * pch;
  int index=0;
  char word[50];
  pch=strrchr(str,' ');
  index=pch-str+1;
  printf ("Last occurence of ' ' found at %d \n",index);
  i=0;
  for(str[index];str[index+i]!=0;i++){                                   //
   word[i]=str[index+i];
  printf ("word: %s \n",word);
  return 0;
out
Last occurence of ' ' found at 6
word: 145frfrfrrfrhyfrfrfrrfrhy
tested in https://www.onlinegdb.com/online_c_compiler
EDIT 2
My code like function
char string[] = "+CBC: 456";
char start=' ';
char extract_string_since_char (char *str, char chr){
  int i=0;
  char temp[10];
  char * pch;
  int index=0;
  char result[10];
  strcpy(temp,str);
  pch=strrchr(temp,chr);
  index=pch-temp+1;
  //printf ("Last occurence of ' ' found at %d \n",index);
  for(;temp[index+i]!=0;i++)
   result[i]=temp[index+i];
 // printf ("word: %s \n",result);
  return result;
void main()  {
 char word[10];
 strcpy(word,extract_string_since_char(string,start));
 printf("%s", word);
out
456
