bearzalk
LCD menu with keypad |
Posted: Tue Nov 19, 2019 12:48 am |
I have a problem with my menu integration. I am currently using keypad to switch menu sections like when I press 'A' on keypad go to a sub-menu or press 'B' to go another sub-menu, when I press '*' inside of these sub-menus then go back to main menu.
I don't have any problem about going to sub-menus when program started but after I press '*' to go to main menu, I can't go back to any of sub-menus.
The code is as following:
char K;
char T;
void MainMenu()
do
K = kbd_getc();
T = K - 48;
lcd_gotoxy(1,1);
printf(lcd_putc,"A)MOD B)SET HOUR");
delay_ms(5);
if((K=='A') || (K=='B') ||(K=='C') || (K=='D'))
printf(lcd_putc,"\f U is zero now");
U=0;
}while(U==1);
void AltMod()
lcd_gotoxy(21,1);
printf(lcd_putc, "\fPRESS * FOR MAIN MENU\n");
delay_ms(5);
lcd_gotoxy(1,2);
printf(lcd_putc,"ENTER NUM=>\n");
void AltModRun()
do
K = kbd_getc();
T = K - 48;
if((K!=0) && (K!='A') && (K!='B') && (K!='C') && (K!='D')&& (K != '*') && (K != '#'))
A = (A*10) + T;
//Don't add Y=20 here, it resets it to 20 in every cycle
Y++;
lcd_gotoxy(Y,1);
printf(lcd_putc,"PRESS # FOR SUBMIT %d",T);
delay_ms(5);
if(K=='#')
num= A;
lcd_gotoxy(21,2);
printf(lcd_putc,"%d NUM IS CHOSEN", num);
delay_ms(5);
if(K == '*')
printf(lcd_putc,"\fINSIDE MOD STAR");
Y=20;
Z=0;
A=0;
}while(Z==1);
kbd_init();
port_b_pullups(true);
set_tris_b(0xF0);
rtc_init();
MainMenu();//To display Main menu when program starts
while(true)
K = kbd_getc();
T = K - 48;
switch(K)
case 'D':
Z=1;
AltMod();
AltModRun();
case '*':
U=1;
printf(lcd_putc, "\fINSIDE CASE STAR");
//MainMenu();
If there is only printf inside case '*' then program works as I want, but when I comment out the printf and put MainMenu(); in there then it doesn't go to anywhere after I press '*', it keeps displaying main menu.
In program's first execution, when I press 'D' then it goes to sub menu, when I press * it goes back to main menu but while in main menu it doesn't go to sub menu when I press A,B,C or D, it only goes to sub menu when I press one of these keys around 20 times. |
Re: LCD menu with keypad |
Posted: Wed Nov 20, 2019 7:55 am |
bearzalk wrote: |
This sounds like a problem with your usage of the kbd_getc() function.
The program in this post shows how to use a timer interrupt to call
the kbd_getc() function every 10 ms.
http://www.ccsinfo.com/forum/viewtopic.php?t=42707&start=4 |
bearzalk
Posted: Wed Nov 20, 2019 8:51 am |
PCM programmer wrote: | bearzalk wrote: |
Thanks a lot for reply, I'll try this. Just a quick question, why does it work when there is only printf in case '*' and can you check this topic sometimes because I'll update the status after I try your solution, I'd like to get your help if this solution does not work. |
