Stream select 9 bit mode dspic33ev256gm004
chaphill
PostPosted: Tue Nov 05, 2019 4:44 pm     Reply with quote
I am working on a data collection system where I poll multiple slave data acquisition boards using the 9 bit addressing mode. I have worked through the slave side of things and have code that I think is close to try but on the master I ran into a problem.
In the 9 bit mode the dspic I am working with (dspic33ev256gm004) expects a word transmit/receive for the 9 bit communication where the low bit of the high byte is a 1 for address interrupts, and is a 0 for data. To accommodate that the CCS getc() and the putc() functions work with words instead of bytes in the 9 bit mode (long_word).
I can see how that works, but when I got to the master which reads the 9 bit data from one #use 232 defined port (stream is named slave for discussion) and wants to write to another 8 bit port (stream named telem)
I can't figure out how to switch between the two streams. Well I can define the stream for the 8 bit one (telem) with fputc(telem) but I don't know how to address the 9 bit stream.
Is there a corresponding fgetc() and fputc() for the 9 bit mode which works with words so I can define the stream?
PostPosted: Wed Nov 06, 2019 12:06 am     Reply with quote
If you have 'LONG_DATA' in the #USE setting up the streams, both fgetc
and fputc then accept/retrieve words. Even more surprising;ly and
impressively fprintf, will also send a word for %c, and the internal
buffering also handles words.
chaphill
PostPosted: Wed Nov 06, 2019 8:54 am     Reply with quote
Fantastic! I hope to have enough hardware put together to begin smoke testing real soon. Thanks!
PostPosted: Wed Nov 06, 2019 9:05 am     Reply with quote
Funnily I'm just doing a job using 9bit, and had queried CCS as to whether
the 'built in' buffering would handle this.
Seems slightly 'odd' to be using the low bit as the flag. Normally using
the high bit is easier, since you can just test this and then omit it.
