Use an Internal Eeprom value
vtrx
PostPosted: Fri Nov 01, 2019 4:15 am     Reply with quote
How to use a value stored in the internal Eeprom to define a value in a table?
Example:
#ROM int8 0xF00000 = {0x00}
   const char USB_DEVICE_DESC[USB_DESC_DEVICE_LEN] ={
      //starts of with device configuration. only one possible
         USB_DESC_DEVICE_LEN, //the length of this report   ==1
         0x01, //the constant DEVICE (DEVICE 0x01)  ==2
         0x10,0x01, //usb version in bcd (pic167xx is 1.1) ==3,4
         ??, //USE HERE VALUE RECORDED AT THE POSITION 0
PostPosted: Fri Nov 01, 2019 4:25 am     Reply with quote
You don't.
Your device descriptor would have to be made a RAM value (get rid
of const), then it can be written.
You can then use:
*(((byte *)&USB_DEVICE_DESC)+4) =read_eeprom(0);
Which will write the byte from the EEPROM into the device descriptor.
vtrx
PostPosted: Fri Nov 01, 2019 6:01 pm     Reply with quote
Could you show me the example above changed?
