EV1527
cvargcal
EV1527
PostPosted: Fri Sep 20, 2019 11:26 am     Reply with quote
Hi, someone has a example for decode 1527 from module 433MHz ?
I need to connect sensors with this protocol to my project.
Thanks in advance
PostPosted: Fri Sep 20, 2019 11:56 am     Reply with quote
You are going to have to decode pulse widths with probably the CCP.
The protocol uses a pulse with of 1/4 the cycle time as a '0', and 3/4
as a '1'. It starts with a '0'. then 20 bits that give the serial number of
the device, then 4 bits that represent the four possible buttons.
There have been code examples posted for such pulse width
protocols posted here, so with some adjustments to the timings
involved, one of these could be modified to extract the sequence.
cvargcal
PostPosted: Sun Sep 22, 2019 3:07 pm     Reply with quote
Ttelmah wrote:
yes thanks,
I see this is the info.
https://tinkerman.cat/post/decoding-433mhz-rf-data-from-wireless-switches-the-data
But i dont know how start
dyeatman
PostPosted: Sun Sep 22, 2019 4:06 pm     Reply with quote
Apparently the devices use ASK modulation.
Try this post to start:
https://www.ccsinfo.com/forum/viewtopic.php?t=57395
Google and Forum Search are some of your best tools!!!!
