Identifying variables used by a library function.
allenhuffman
PostPosted: Fri Aug 30, 2019 10:58 am     Reply with quote
Before I do this manually, does anyone know if there is an easy way to identify any global/static functions used by a library call? For example:
i2c_isr_state ();
To work around an issue we have encountered, I need to identify any variables being brought in by a library function so I can inspect the symbol table and see if any are int8s, and if they share memory with other variables.
Thanks... (I plan to manually use test code and just bring in a call, one by one, and look at the symbol table.)
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
http://www.whywouldyouwanttodothat.com ?
PostPosted: Fri Aug 30, 2019 11:54 am     Reply with quote
Compile a program. Look at the .SYM file. Notice compiler-generated
variables:
017 @INTERRUPT_AREA
018 @INTERRUPT_AREA
019 @I2C_STATE
01A ssp_isr.temp
F55 CCP_5
F55 CCP_5_LOW
F56
Also put the .LST file in Symbolic mode and see it:
.................... #int_ssp
.................... void ssp_isr(void)
.................... int8 temp;
.................... temp = i2c_isr_state();
000AE: BTFSC SSP1STAT.ADDRESS
000B0: BRA 00B8
000B2: CLRF @I2C_STATE
000B4: BTFSC SSP1STAT.WRITE
000B6: BSF @I2C_STATE.7
000B8: MOVF @I2C_STATE,W
000BA: INCF @I2C_STATE,F
000BC: MOVWF temp
000BE: BCF PIR1.SSP1IF
000C0: GOTO 0060
Test program:
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#use i2c(Slave, I2C1)
#int_ssp
void ssp_isr(void)
int8 temp;
while(TRUE);
allenhuffman
PostPosted: Fri Aug 30, 2019 1:51 pm     Reply with quote
variables:
Thanks! Yep. That is my "manual" approach. I have been sticking in every library call I find in our ISRs in and looking at the results. So far, so good.
An OS company I worked for used to provide stub files for our libraries, allowing symbol table lookup and such without giving out the source code. I don't think that is very common, though.
PostPosted: Sun Sep 01, 2019 11:55 am     Reply with quote
Remember also that 90% of the values will actually just be held in
the scratch area, rather than in specific variables.
