Levett Prins Guest
Read to EEPROM from RS232 at 19200 baud rate? |
Posted: Sat Jun 21, 2003 6:23 am |
I am using a Siemens TC35 GSM modem that operates stable at 19200 baud rate and I want to read the modem output to a PIC16F877 EEPROM.
Is this technically possible and does anyone perhaps have code for this?
Thank you
Levett
___________________________
Original Post ID: 144515440 |
Tomi Guest
Re: Read to EEPROM from RS232 at 19200 baud rate? |
Posted: Sat Jun 21, 2003 9:48 am |
WHY do you want to save TC35's answers?
:=I am using a Siemens TC35 GSM modem that operates stable at 19200 baud rate and I want to read the modem output to a PIC16F877 EEPROM.
:=Is this technically possible and does anyone perhaps have code for this?
:=Thank you
:=Levett
Original Post ID: 144515441 |
Levett Prins Guest
Posted: Sun Jun 22, 2003 1:50 am |
I am saving IO parameters on the TC35 sim (e.g. analog min & max limits, port description, unit of measure etc.) and need to write it to EEPROM for use in the program.
Original Post ID: 144515445 |
Tomi Guest
Posted: Sun Jun 22, 2003 3:29 am |
<font face="Courier New" size=-1>Then you don't have to save any incoming byte stream into the EEPROM .
Just define the record structure and write functions like SaveToSIM() (if the record is changed call this function to save the modified content to SIM) and RestoreFromSIM() (call it from early main() after reset). These function could have a RAM buffer for serial comm.
:=I am saving IO parameters on the TC35 sim (e.g. analog min & max limits, port description, unit of measure etc.) and need to write it to EEPROM for use in the program.</font>
Original Post ID: 144515447 |
Levett Prins Guest
Posted: Mon Jun 23, 2003 11:49 pm |
I than need a RAM buffer for a 150 (max SMS length) character string. This is what I am trying to prevent!
Original Post ID: 144515503 |
Tomi Guest
Posted: Tue Jun 24, 2003 2:02 am |
At first, the SMS length is never limited to 150 characters. The maximum SMS bit length is 1120 bits what means 140 characters in 8-bit mode and 160 characters in 7-bit mode.
Next, if you use HW UART then you have 520 usec time between bytes what means cca. 1 msec for byte pairs. This time is long enough to receive a character pair and to convert it to binary (if you store it as characters).
If I strongly understand your concept you want to use the SIM memory based on "AT+CMGW" commands. In this case the big buffer is not necessary for write; you could have even 1 second between bytes.
The storage method: I would avoid to use pure string-based storage like "printf("\%d",myvar);". You can use "print quotable" method as described in some Internet RFC documents.
So the big buffer is not necessary for read.
All in all, I would use something like this (as I really do in 100+ TC35 Terminal based installations):
To send (save) an array:
printf("AT+CMGW=\"+36..........\"\r\n"); // init write
.....// wait for prompt
printf("[format_header]",[parameter list]);
char i,upper,lower;
for (i=0;i<ARRAYLENGTH;i++) {
lower = upper = MYARRAY[i];
lower &= 0x0F; // lower nibble
lower += '0'; // be sure it is a legal character
upper >>= 4;
upper += '0';
putch(lower);
putch(upper);
putch(0x1A); // Ctrl+Z for terminate writing
...........// wait for a good status
To retrieve a stored byte, ask the stored SMS, read in the header, then when your 2-byte buffer (not too big, isn't it ?) is full:
MYARRAY[actIdx++] = buffer[0] - '0' + ((buffer[1] - '0') << 4);
:=I than need a RAM buffer for a 150 (max SMS length) character string. This is what I am trying to prevent!
Original Post ID: 144515508 |
