Snapshot
gtx15
Snapshot
PostPosted: Sat Jul 27, 2019 4:30 pm     Reply with quote
Trying to understand the Snapshot function in the debugger menu. Specifically the peripherals. I checked this box but get nothing about peripherals in the file.
PostPosted: Sun Jul 28, 2019 5:25 am     Reply with quote
I don't think the CCS IDE, has a 'snapshot' feature. So I suspect you
are talking about a feature of the MPLAB X IDE?. IN which case you need
to ask on the MPLAB forums not here.
are talking about a feature of the MPLAB X IDE?. In which case you need
PostPosted: Sun Jul 28, 2019 6:34 am     Reply with quote
This CCS webpage does list Snapshot as being a feature of the debugger:
http://www.ccsinfo.com/content.php?page=c-aware_debug
PostPosted: Sun Jul 28, 2019 10:02 am     Reply with quote
Fair enough. I don't remember ever coming across it in the CCS IDE.
I note it says you can select what it is to record. Presumably this is meant to
be controlled by the tick boxes being referred to. 'Peripherals', is actually
an odd thing to talk about, since these are just registers.
