Sparkfun QWIIC Openlog example.
Rocket
PostPosted: Mon Jul 29, 2019 12:43 am     Reply with quote
Hi, noob question here. I would like to use the I2C openlog device from Sparkfun. I have been unable to port the code from arduino to ccs. If someone could point me in the right direction I would be very grateful. Thank you.
J.I.L.
PostPosted: Mon Jul 29, 2019 2:45 am     Reply with quote
I assume you actually mean the SparkFun Qwiic OpenLog.
https://www.sparkfun.com/products/15164
This board uses an AtMega328 microcontroller. This is not a PIC.
The product has a bootloader for application code. It runs Arduino code,
compiled with the Arduino compiler. You can't compile CCS code, which
runs on PICs, and download it to an Arduino AtMega328 and expect it to
work. It won't.
PostPosted: Mon Jul 29, 2019 4:57 am     Reply with quote
Yeesh, I'm confused (only 1 coffee so far...)
I read (OK, scanned ) the 'datasheet' and I thought it was just an IIC version of the logger, though it has the 'option' to download a program into it, presumably to make a 'smart' I2C peripheral...
I did see it's a 3 volt device.
If it IS like it's 'cousin', then one could just convert Ardunio code into PIC C to use it.
I need more coffee...
Jay
Gabriel
PostPosted: Mon Jul 29, 2019 6:40 am     Reply with quote
I think he just wants code to write data via i2c to the logger, not re write the procesor code.
Sparkfun provides a manual with the commands.
You need to write the driver.
Ccs provides standard i2c functions.
G.
CCS PCM 5.078 & CCS PCH 5.093
Rocket
PostPosted: Mon Jul 29, 2019 9:54 am     Reply with quote
Gabriel, you are correct, I am wanting to write to the logger.
Something like printf(Logger,"Hello World"); would be great.
J.I.L.
PostPosted: Mon Jul 29, 2019 1:21 pm     Reply with quote
Since I don't have one of those modules, I can't cut code for a 'driver' or 'library' as I can't test it.
You can take the Ardunio library and convert into CCS C though. A bit of a challenge, but you would be a much better programmer in the end !
Remember that module is 3 volts, so you cannot directly wire it to a 5 volt PIC ! Either choose a PIC that will run ( at desired clock speed) on 3 volts or add appropriate 'logic level conversion' module.
Jay
PostPosted: Mon Jul 29, 2019 8:36 pm     Reply with quote
You didn't tell us, so I did a search. It looks like this is the source code
file that would have to be converted to CCS, so you could send
commands to the Qwiic OpenLog device:
https://github.com/sparkfun/SparkFun_Qwiic_OpenLog_Arduino_Library/blob/master/src/SparkFun_Qwiic_OpenLog_Arduino_Library.cpp
Rocket
PostPosted: Mon Jul 29, 2019 11:50 pm     Reply with quote
Thanks for all the responses. It is time I learned to code.
J.I.L.
