championx
CDC bootloader 18F67j50 [Solved] |
Posted: Thu Jul 11, 2019 8:24 pm |
Hi! im using the example cdc bootloader from CCS. Compiler version 5.046.
The bootloader works fine, the firmware that i need to load over usb works fine with no bootloader too.
The thing is, that when i include the usb_bootloader.h on the code, compile it and then load it using the bootloader, the code does not work properly...
The board has a 128x64 lcd, and with the code loaded using the bootloader, the words and drawings have some errors... and some functions doesnt work...
I will read the hex file using pickit to see if there any error on the loaded hex...
Any hint?
(SORRY FOR MY INGLISH). |
championx
Posted: Thu Jul 11, 2019 10:45 pm |
Ok, here's an update... the hex files downloaded from the pic using pickit seems ok...
But, in the loaded code, if I comment the interrupts, the code runs fine... could be an error on the ORG statements used on the usb bootloader? I didn't change them.
#define LOADER_START (0)
#define LOADER_SIZE (0x2000)
#if defined(__USB_87J50__)
#define APPLICATION_END (getenv("PROGRAM_MEMORY")-9) //configuration bits
#elif defined(__PCD__)
#define APPLICATION_END (getenv("PROGRAM_MEMORY")-2)
#else
#define APPLICATION_END (getenv("PROGRAM_MEMORY")-1)
#if defined(__PCM__)
#define LOADER_END (LOADER_SIZE+0x40-1)
#elif defined(__PCH__)
#define FLASH_SIZE getenv("FLASH_ERASE_SIZE")
#if (((LOADER_SIZE) % FLASH_SIZE) == 0 ) //IF LOADER_SIZE is even flash boundary
#define LOADER_END (LOADER_SIZE-1)
#else //ELSE, goto next even boundary
#define LOADER_END (((LOADER_SIZE)+FLASH_SIZE-((LOADER_SIZE)%FLASH_SIZE))-1)
#define FLASH_SIZE getenv("FLASH_ERASE_SIZE")/2
#if (((LOADER_START+LOADER_SIZE) % FLASH_SIZE) == 0)
#define LOADER_END (LOADER_START+LOADER_SIZE-1)
#else
#define LOADER_END (LOADER_START+(LOADER_SIZE+FLASH_SIZE-((LOADER_SIZE)%FLASH_SIZE))-1)
#else
#error PCM, PCH, and PCD only supported
#define APPLICATION_START (LOADER_END+1)
#if defined(__PCH__)
#define APPLICATION_ISR (APPLICATION_START+8)
#elif defined(__PCM__)
#define APPLICATION_ISR (APPLICATION_START+4)
//// --- end configuration --- ////////////////////////////////////////////
#ifdef _bootloader
// bootloader won't use interrupts, instead it will poll USB IF
#define USB_ISR_POLLING
Provide an empty application, so if you load this .HEX file into the pic
without an application this will prevent the pic from executing unknown code.
#org APPLICATION_START,APPLICATION_START+0xF
void BlankApplication(void)
while(TRUE);
//we need to prevent the loader from using application space
#if (APPLICATION_END > 0x10000)
#org APPLICATION_START+0x10, 0xFFFF {}
#if (APPLICATION_END > 0x20000)
#org 0x10000, 0x1FFFF {}
#org 0x20000, APPLICATION_END {}
#else
#org 0x10000, APPLICATION_END {}
#else
#org APPLICATION_START+0x10, APPLICATION_END {}
#define USB_STRINGS_OVERWRITTEN
char USB_STRING_DESC_OFFSET[]={0,4,12};
#define USB_CONFIG_PID 0x000c
// Here is where the "CCS" Manufacturer string and "SERIAL DEMO" are stored.
// Strings are saved as unicode.
// These strings are mostly only displayed during the add hardware wizard.
// Once the operating system drivers have been installed it will usually display
// the name from the drivers .INF.
char const USB_STRING_DESC[]={
//string 0
4, //length of string index
0x03, //USB_DESC_STRING_TYPE, //descriptor type 0x03 (STRING)
0x09,0x04, //Microsoft Defined for US-English
//string 1 - manufacturer
8, //length of string index
'C',0,
'C',0,
'S',0,
//string 2 - product
38, //length of string index
'C',0,
'C',0,
'S',0,
' ',0,
'C',0,
'D',0,
'C',0,
' ',0,
'B',0,
'o',0,
'o',0,
't',0,
'l',0,
'o',0,
'a',0,
'd',0,
'e',0,
'r',0
#endif //_bootloader
#ifndef _bootloader
//in the application, this moves the reset and isr vector out of the bootload
//space. it then reserves the loader space from being used by the application.
#build(reset=APPLICATION_START, interrupt=APPLICATION_ISR)
#org 0, LOADER_END {}
#endif |
championx
Posted: Sat Jul 13, 2019 6:56 pm |
Hi! I really can't make it work. Is there an error for the interrupt vector positioning on the ccs example? |
Posted: Sat Jul 13, 2019 7:22 pm |
Look at the code at the end of the Ex_usb_bootloader.c file.
In vs. 5.085, it looks like this at the end:
#if defined(__PCD__)
#int_default
#else
#int_global
void isr(void)
jump_to_isr(APPLICATION_ISR);
If your version only has #int_default, then it's a CCS source code bug.
That bug has been fixed, as of vs. 5.066, with the code shown above
which now uses #int_global for PCM and PCH.
Since you are using vs. 5.046 it might have the bug in it.
See Ttelmah's post near the end of this 3-page thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=55739&start=30 |
championx
Posted: Sun Jul 14, 2019 7:21 am |
yes!!! it works now! thanks a lot PCM programmer |
