HS OSC in FUSES and "setup_oscillator"
mcmsat
PostPosted: Mon May 27, 2019 10:58 am     Reply with quote
Hello!
Selecting HS in the FUSES and in #use delay (clock = 20000000) and I use 8MHz in "setup_oscillator", is it a bad setting? Assuming that I have 8MHz crystal and want to set the ADC clock to run at 8MHz?
The code below shows what I mean:
#include <16F886.h>
#device ADC = 10
#FUSES NOWDT,HS, PUT, NOPROTECT, NOMCLR, NOCPD, NOBROWNOUT,NOIESO, FCMEN,
#use delay(clock = 20000000)
void init()                                  // Hardware initialization
  setup_oscillator(OSC_8MHZ);
  setup_adc(ADC_CLOCK_DIV_8);                // 8Tosc ADC conversion time
  setup_adc_ports( sAN12 | sAN11 | sAN9 | sAN10 | sAN8); // Select Analog Inputs
  setup_comparator(NC_NC_NC_NC);         // disable comparator module
All is well even in the well!
PostPosted: Mon May 27, 2019 12:00 pm     Reply with quote
The delay setting must match what speed your chip is actually running at.
Otherwise every timing based operation will be wrong.
However you seem very confused. Setup_oscillator is to configure the
_internal_ oscillator, not an external crystal. You need to physically
look at your board. Is there a crystal?. On your chip, if there is it'll be
connected to pins 9 & 10. If ir is present, then look on it. It'll have a number
giving it's frequency.
If there is a crystal, then get rid of 'setup oscillator', and put the
frequency value of the crystal into #use delay.
If there is not a crystal, then change #use delay to 8MHz, and get rid
of the HS fuse.
mcmsat
PostPosted: Mon May 27, 2019 12:57 pm     Reply with quote
Solved! Thanks for your explanations.
mcmsat
PostPosted: Mon May 27, 2019 1:40 pm     Reply with quote
Sorry, if I may ask again, can I use "setup_oscillator(OSC_8MHz)"on those PICs that have 32MHz and 16MHz internal oscillator?
Or must I set it with their internal oscillator speed in case I want to make use of the "INTRC_IO"?
PostPosted: Mon May 27, 2019 1:52 pm     Reply with quote
Many chips with internal oscillators have programmable postscalers for these.
Many of the older chips only had a 4MHz oscillator. No other settings.
Then later ones typically have a 8MHz oscillator a postscaler (that can give
normally, 8, 4, 2, 1MHz, and a PLL that can be fed from the 8MHz or 4Mhz
output to give 16 and 32MHz.
Understand that the setup file for whatever chip you use, will only contain
the options that are supported by it's oscillator. The chip's data sheet
will also show what frequencies are available from the internal oscillator.
mcmsat
PostPosted: Mon May 27, 2019 2:35 pm     Reply with quote
Ok understood. Thanks.
jeremiah
PostPosted: Mon May 27, 2019 6:42 pm     Reply with quote
One thing to be aware of that I ran into recently. If the setup oscillator call you put in cannot be achieved by the FUSES you have chosen, it will silently change your fuses to whatever the setup_oscillator call will need. It did this to me on a PIC24 chip using one of the more recent versions of the compiler.
I had the fuses and #use delay() setup for 8MHz for normal operation, but added a call to setup_oscillator() which changed it to 32MHz (to run a quick calc). It changed the FUSES to only support the 32MHz so all of my UARTs and such stopped working. Took me a bit to figure out what happened since it had been working fine for the last few months (until that change).
I expected that from the precompiler stuff (#use delay() for example), but a runtime call of a function caught me off guard.
It was my fault for not checking the datasheet and not double checking the fuses after making the change, but like I said...working fine for months with no issue, so I wasn't expecting a FUSE change.
PostPosted: Mon May 27, 2019 11:08 pm     Reply with quote
I think you will find it is the #use delay that did the 'override'.
If you have a #use delay statement _after_ the fuse settings, and it
conflicts, the compiler will use the fuses that match the delay, not those
you have already set.
Place the fuses after the #use delay, and your fuses override those
implicit in the delay statement.
mcmsat
PostPosted: Tue May 28, 2019 12:34 am     Reply with quote
A Learner has big ears! Taken into the PIC memory address in on side of my head.
jeremiah
PostPosted: Tue May 28, 2019 5:39 pm     Reply with quote
No it wasn't the use delay, which was set to 8MHz. I'm aware of how the order affects the fuses. Commenting out the setup_oscillator() call changed the fuses back to what I set. Uncommenting the setup_oscillator() call changed them to the unworking state.
EDIT:
Here ya go with an example:
#include <24fj256ga406.h>
#use delay(clock = 8MHz)
#FUSES FRC
#FUSES NOPR
void main(){
   setup_oscillator(OSC_INTERNAL,32000000,8000000);
Compiler version 5.078 and 5.080
Note that the placement of the #use delay() doesn't actually matter in this case since I specified "clock=" instead of something like "internal=" or "crystal=", which do change fuses. The result is the same even if the #use delay is after the fuses in this configuration (again due to using "clock=").
with that setup_oscillator() line of code the fuses change to:
Word  7L: FFE1   FRC_PLL PLL4X IESO
          H: 0000
take out the setup_oscillator() line and the fuses go back to normal
Word  7L: FFF8   FRC NOPLL IESO
          H: 0000
Again, my fault for not checking the datasheet and seeing the fuses I chose wouldn't work with the setup_oscillator() call. I would have hoped for a compiler error instead of silently changing them. I know it is a very grey line, but having a runtime call change fuses silently was a bit more jarring for me than a precompiler call (like the order and type of #use delay() for example).
Also note that while this example is simple and has the setup_oscillator() call right in the main(), my actual case was 20k lines of code and the call was buried in a function only called when certain commands were to be given. It still affected the fuses in the same way.
PostPosted: Wed May 29, 2019 3:07 am     Reply with quote
Yes. You can see 'why' it has to do this. On this chip the PLLMODE, is set
in the fuses and cannot be changed. So since you are asking for *4PLL
in the setup_oscillator, it sets this in the fuses.
The error is really that it is done 'silently'. A simple warning that 'PLL
mode changed based on oscillator setting', would save any annoyance.
Ask CCS if they could warn in this situation.
jeremiah
PostPosted: Wed May 29, 2019 8:46 am     Reply with quote
I'd be more of the mind to say for a runtime call to generate a compiler error. Warnings for precompiler directives, as those are the normal means for changing things like FUSES, but errors for runtime calls.
PostPosted: Wed May 29, 2019 1:02 pm     Reply with quote
Yes, Something simple like 'setup_oscillator mode selected requires PLL*4
fuse setting'.
