vtrx
Large Descriptor |
Posted: Tue May 21, 2019 9:08 am |
What do I need to change to use a descriptor greater than 255 bytes?
Code: | //if a class has an extra descriptor not part of the config descriptor,
// this lookup table defines the size of that descriptor.
//first element is the config number (if your device has more than one config)
//second element is which interface number
//set element to 0xFFFF if this config/interface combo doesn't exist
const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[USB_NUM_CONFIGURATIONS][3] =
//config 1
//interface 0
63,
//interface 1
32,
//interface 2
>256//large descriptor part here
I want to try to implement force feedback. |
Posted: Tue May 21, 2019 10:42 am |
Er. You can't.
The first byte of a USB descriptor, is it's length. A one byte value.
So all USB descriptors are inherently limited to 255 bytes or less.
(since this can only give 1 to 255 as a length).
Why on earth do you think force feedback requires a > 255 byte descriptor?.
<https://www.microchip.com/forums/m958105.aspx> |
vtrx
Posted: Tue May 21, 2019 11:34 am |
Code: | 0x05,0x01, // Usage Page Generic Desktop
0x09,0x04, // Usage Joystick
0xA1,0x01, // Collection Application
0x85,0x01, // Report ID 1
0x05,0x09, // [0x03]USAGE PAGE (BUTTON)
0x19,0x01, // [0x04]USAGE_MINIMUM(BUTTON 1)
0x29,0x10, // [0x05]USAGE_MAXIMUM(BUTTON 16)
0x15,0x00, // [0x06]LOGICAL_MINIMUM
0x25,0x01, // [0x07]LOGICAL_MAXIMUM
0x35,0x00, // [0x08]PHYSICAL_MINIMUM
0x45,0x01, // [0x09]PHYSICAL_MAXIMUM
0x75,0x01, // [0x0A]REPORT_SIZE
0x95,0x10, // [0x0B]REPORT_COUNT
0x81,0x02, // [0x0C]INPUT
0x05,0x01, // [0x0D]USAGE PAGE (GENERIC DESKTOP CONTROLS)
0x09,0x39, // [0x0E]USAGE(HAT_SWITCH)
0x15,0x00, // [0x0F]LOGICAL_MINIMUM
0x25,0x07, // [0x10]LOGICAL_MAXIMUM
0x35,0x00, // [0x11]PHYSICAL_MINIMUM
0x46,0x3B,0x01, // [0x12]PHYSICAL_MAXIMUM
0x65,0x14, // [0x13]UNIT
0x75,0x04, // [0x14]REPORT_SIZE
0x95,0x01, // [0x15]REPORT_COUNT
0x81,0x42, // [0x16]INPUT
0x65,0x00, // [0x17]UNIT
0x95,0x01, // [0x18]REPORT_COUNT
0x81,0x01, // [0x19]INPUT
0x09,0x30, // [0x1A]USAGE(X)
0x09,0x31, // [0x1B]USAGE(Y)
0x09,0x32, // [0x1C]USAGE(Z)
0x09,0x33, // [0x1D]USAGE(Rx)
0x15,0x00, // [0x1E]LOGICAL_MINIMUM
0x26,0x00,0x04, // [0x1F]LOGICAL_MAXIMUM
0x35,0x00, // [0x20]PHYSICAL_MINIMUM
0x46,0x00,0x04, // [0x21]PHYSICAL_MAXIMUM
0x75,0x10, // [0x22]REPORT_SIZE
0x95,0x04, // [0x23]REPORT_COUNT
0x81,0x02, // [0x24]INPUT
Input
Collection Datalink (sub-collection)
Physical Interface (Usage: PID State report)
state report: 5X1bit
Padding: 3bit
PID Device Control: 1bit
Effect Block Index: 7bit
0x05,0x0F, // Usage Page Physical Interface
0x09,0x92, // Usage PID State report
0xA1,0x02, // Collection Datalink (logical)
0x85,0x02, // Report ID 2
0x09,0x9F, // Usage Device is Pause
0x09,0xA0, // Usage Actuators Enabled
0x09,0xA4, // Usage Safety Switch
0x09,0xA5, // Usage Actuator Override Switch
0x09,0xA6, // Usage Actuator Power
0x15,0x00, // Logical Minimum 0
0x25,0x01, // Logical Maximum 1
0x35,0x00, // Physical Minimum 0
0x45,0x01, // Physical Maximum 1
0x75,0x01, // Report Size 1
0x95,0x05, // Report Count 5
0x81,0x02, // Input (Variable)
0x95,0x03, // Report Count 3
0x81,0x03, // Input (Constant, Variable)
0x09,0x94, // Usage Effect Playing
0x95,0x01, // Report Count 1
0x09,0x22, // Usage Effect Block Index
0x15,0x01, // Logical Minimum 1
0x25,0x28, // Logical Maximum 28h (40d)
0x35,0x01, // Physical Minimum 1
0x45,0x28, // Physical Maximum 28h (40d)
0x75,0x07, // Report Size 7
0xC0 , // End Collection
Output
Collection Datalink:
Usage Set Effect Report
Effect Block Index: 8bit
subcollection Effect Type
12 effect types, 8bit each
0x09,0x21, // Usage Set Effect Report
0xA1,0x02, // Collection Datalink (Logical)
0x75,0x08, // Report Size 8
0x91,0x02, // Output (Variable)
0x09,0x25, // Usage Effect Type
0x09,0x26, // Usage ET Constant Force
0x09,0x27, // Usage ET Ramp
0x09,0x30, // Usage ET Square
0x09,0x31, // Usage ET Sine
0x09,0x32, // Usage ET Triangle
0x09,0x33, // Usage ET Sawtooth Up
0x09,0x34, // Usage ET Sawtooth Down
0x09,0x40, // Usage ET Spring
0x09,0x41, // Usage ET Damper
0x09,0x42, // Usage ET Inertia
0x09,0x43, // Usage ET Friction
0x09,0x28, // Usage ET Custom Force Data
0x25,0x0C, // Logical Maximum Ch (12d)
0x45,0x0C, // Physical Maximum Ch (12d)
0x91,0x00, // Output
0x09,0x50, // Usage Duration
0x09,0x54, // Usage Trigger Repeat Interval
0x09,0x51, // Usage Sample Period
0x26,0xFF,0x7F, // Logical Maximum 7FFFh (32767d)
0x46,0xFF,0x7F, // Physical Maximum 7FFFh (32767d)
0x66,0x03,0x10, // Unit 1003h (4099d)
0x55,0xFD, // Unit Exponent FDh (253d)
0x75,0x10, // Report Size 10h (16d)
0x55,0x00, // Unit Exponent 0
0x66,0x00,0x00, // Unit 0
0x09,0x52, // Usage Gain
0x26,0xFF,0x00, // Logical Maximum FFh (255d)
0x46,0x10,0x27, // Physical Maximum 2710h (10000d)
0x09,0x53, // Usage Trigger Button
0x25,0x08, // Logical Maximum 8
0x45,0x08, // Physical Maximum 8
0x09,0x55, // Usage Axes Enable
0x09,0x30, // Usage X
0x09,0x31, // Usage Y
0x95,0x02, // Report Count 2
0x09,0x56, // Usage Direction Enable
0x91,0x03, // Output (Constant, Variable)
0x09,0x57, // Usage Direction
0x0B,0x01,0x00,0x0A,0x00, // Usage Ordinals: Instance 1
0x0B,0x02,0x00,0x0A,0x00, // Usage Ordinals: Instance 2
0x66,0x14,0x00, // Unit 14h (20d)
0x55,0xFE, // Unit Exponent FEh (254d)
0x47,0xA0,0x8C,0x00,0x00, // Physical Maximum 8CA0h (36000d)
0x09,0xA7, // Usage Undefined
0x09,0x5A, // Usage Set Envelope Report
0x09,0x5B, // Usage Attack Level
0x09,0x5D, // Usage Fade Level
0x09,0x5C, // Usage Attack Time
0x09,0x5E, // Usage Fade Time
0x45,0x00, // Physical Maximum 0
0x09,0x5F, // Usage Set Condition Report
0x85,0x03, // Report ID 3
0x09,0x23, // Usage Parameter Block Offset
0x75,0x04, // Report Size 4
0x09,0x58, // Usage Type Specific Block Off...
0x75,0x02, // Report Size 2
0x15,0x80, // Logical Minimum 80h (-128d)
0x25,0x7F, // Logical Maximum 7Fh (127d)
0x36,0xF0,0xD8, // Physical Minimum D8F0h (-10000d)
0x09,0x60, // Usage CP Offset
0x09,0x61, // Usage Positive Coefficient
0x09,0x62, // Usage Negative Coefficient
0x09,0x63, // Usage Positive Saturation
0x09,0x64, // Usage Negative Saturation
0x09,0x65, // Usage Dead Band
0x09,0x6E, // Usage Set Periodic Report
0x85,0x04, // Report ID 4
0x09,0x70, // Usage Magnitude
0x09,0x6F, // Usage Offset
0x09,0x71, // Usage Phase
0x09,0x72, // Usage Period
0x09,0x73, // Usage Set Constant Force Rep...
0x85,0x05, // Report ID 5
0x16,0x01,0xFF, // Logical Minimum FF01h (-255d)
0x09,0x74, // Usage Set Ramp Force Report
0x85,0x06, // Report ID 6
0x09,0x75, // Usage Ramp Start
0x09,0x76, // Usage Ramp End
0x09,0x68, // Usage Custom Force Data Rep...
0x85,0x07, // Report ID 7
0x09,0x6C, // Usage Custom Force Data Offset
0x26,0x10,0x27, // Logical Maximum 2710h (10000d)
0x09,0x69, // Usage Custom Force Data
0x15,0x81, // Logical Minimum 81h (-127d)
0x46,0xFF,0x00, // Physical Maximum FFh (255d)
0x95,0x0C, // Report Count Ch (12d)
0x92,0x02,0x01, // Output (Variable, Buffered)
0x09,0x66, // Usage Download Force Sample
0x85,0x08, // Report ID 8
0x09,0x77, // Usage Effect Operation Report
0x85,0x0A, // Report ID Ah (10d)
0x09,0x78, // Usage Effect Operation
0x09,0x79, // Usage Op Effect Start
0x09,0x7A, // Usage Op Effect Start Solo
0x09,0x7B, // Usage Op Effect Stop
0x25,0x03, // Logical Maximum 3
0x09,0x7C, // Usage Loop Count
0x09,0x90, // Usage PID Block Free Report
0x85,0x0B, // Report ID Bh (11d)
0x09,0x96, // Usage PID Device Control
0x85,0x0C, // Report ID Ch (12d)
0x09,0x97, // Usage DC Enable Actuators
0x09,0x98, // Usage DC Disable Actuators
0x09,0x99, // Usage DC Stop All Effects
0x09,0x9A, // Usage DC Device Reset
0x09,0x9B, // Usage DC Device Pause
0x09,0x9C, // Usage DC Device Continue
0x25,0x06, // Logical Maximum 6
0x09,0x7D, // Usage Device Gain Report
0x85,0x0D, // Report ID Dh (13d)
0x09,0x7E, // Usage Device Gain
0x09,0x6B, // Usage Set Custom Force Report
0x85,0x0E, // Report ID Eh (14d)
0x09,0x6D, // Usage Sample Count
0x09,0xAB, // Usage Create New Effect Report
0xB1,0x00, // Feature
0x09,0x3B, // Usage Reserved
0x26,0xFF,0x01, // Logical Maximum 1FFh (511d)
0x46,0xFF,0x01, // Physical Maximum 1FFh (511d)
0x75,0x0A, // Report Size Ah (10d)
0xB1,0x02, // Feature (Variable)
0x75,0x06, // Report Size 6
0xB1,0x01, // Feature (Constant)
0x09,0x89, // Usage Block Load Status
0x09,0x8B, // Usage Block Load Status
0x09,0x8C, // Usage Block Load Success
0x09,0x8D, // Usage Block Load Full
0x09,0x8E, // Usage Block Load Error
0x45,0x03, // Physical Maximum 3
0x09,0xAC, // Usage Undefined
0x27,0xFF,0xFF,0x00,0x00, // Logical Maximum FFFFh (65535d)
0x47,0xFF,0xFF,0x00,0x00, // Physical Maximum FFFFh (65535d)
0x09,0x7F, // Usage PID Pool Report
0x09,0x80, // Usage RAM Pool size
0x09,0x83, // Usage Simultaneous Effects Max
0x09,0xA9, // Usage Device Managed Pool
0x09,0xAA, // Usage Shared Parameter Blocks
0xB1,0x03, // Feature (Constant, Variable)
0xC0, // End Collection
0xC0 // End Collection
Reference;
https://www.microchip.com/forums/m958105.aspx |
Posted: Tue May 21, 2019 2:00 pm |
If you look at the code you are copying from, the descriptor size is just
64bytes. The big block is the report. |
vtrx
Posted: Tue May 21, 2019 2:22 pm |
Is it possible to implement this example with CCS? |
Joined: 01 Jul 2010 Posts: 9163 Location: Greensville,Ontario
Posted: Tue May 21, 2019 2:57 pm |
yes, you can though I can't help as I stay away from USB...too dang slow, too complicated and NOT interrupt driven. |
Posted: Wed May 22, 2019 12:49 am |
Sorry Jay, but for a force feedback joystick, USB is the only solution.
and (of course) USB is interrupt driven. It's just that there is not a nice
simple interrupt for an event. Instead the handler has to interpret the
packet and work out what it is.
Now on this, the data here is the report descriptor. It contains separate
descriptors for a huge number of different possible packets that the
stick can generate (I count about 23...). This goes into the block starting:
const char USB_CLASS_SPECIFIC_DESC[] =
Have a look at the example for multihid, which shows a larger class
descriptor. |
