David Pouzar
EERAM Microchip 47C16 I2C not losing values when power cycle |
Posted: Thu May 02, 2019 1:55 pm |
Hi All:
I just started to work with EERAM 47c16 with dsPIC33EP512MU810 using Mikro boards. I can write and read the data fine, reset the board and the data is ok. When I power off the unit and back on I lose the data.
I figured out the address to be A0 and A1, my jumpers are all 0.
// Write a byte at the address in the EEPROM new
void write_eeprom_ext(int32 address, char data)
int i;
char datar;
int32 address2;
unsigned int8 addresshi;
unsigned int8 addresslo;
unsigned int8 write_ext;
unsigned int8 read_ext;
unsigned int8 ack;
//does the value need to be changed
datar= read_eeprom_ext(address);
if(datar==data)
return; //data is the same no write needed
write_ext=0xA0;
read_ext=0xA1;
address2=address;//&0x7FFFF;// force address consistency
while (address2>=0x20000)
address2-=0x20000;// chip address space
write_ext+=2; // next chip
read_ext+=2;
if(address2>=0x10000)// block address space
address2-=0x10000;
write_ext+=8; // second block in the chip
read_ext+=8;
addresslo=(address2);
address2>>=8;
addresshi=(address2);
eeprom_errors_flag=1;
for (i=0;i<3;i++)
i2c_start(I2C_INT);
i2c_write(I2C_INT,write_ext);
i2c_write(I2C_INT,addresshi); //upper address
i2c_write(I2C_INT,addresslo); //lower address
i2c_write(I2C_INT,data);
i2c_stop(I2C_INT);
ack=1; // EEPROM does not ACK when not ready
while(ack&(i<100))
i2c_start(I2C_INT);
ack=i2c_write(I2C_INT,write_ext); // ACK will end the loop (active low)
i2c_stop(I2C_INT);
i++;
i2c_start(I2C_INT);
i2c_start(I2C_INT);
i2c_write(I2C_INT,read_ext);
datar=i2c_read(I2C_INT,0);
i2c_stop(I2C_INT);
if(data==datar){
eeprom_errors_flag=0;
// Read a byte from address in EEPROM new
char read_eeprom_ext(int32 address)
char data;
int32 address2;
//load lowest locations
write_ext=0xA0;
read_ext=0xA1;
read_ext+=2;
address2-=0x10000;
read_ext+=8;
address2>>=8;
i2c_start(I2C_INT);
i2c_start(I2C_INT);
data=i2c_read(I2C_INT,0);
i2c_stop(I2C_INT);
return(data);
The part I do not understand is the HW (Hardware) and the Control bytes(code). http://ww1.microchip.com/downloads/en/DeviceDoc/20005371C.pdf
Please advice me thank you.. |
asmallri
Posted: Thu May 02, 2019 4:25 pm |
I cannot tell form the code snippet you have posted, Brownout Detect needs to be enabled to force the PIC into reset as the power supply rails drop when power is removed. This will prevent the PIC from crashing and running amok as the supply rail voltage collapses. _________________ Regards, Andrew
Re: EERAM Microchip 47C16 I2C not losing values when power c |
Posted: Thu May 02, 2019 7:05 pm |
David Pouzar wrote: | Hi All:
The eeram is a 5v part, whereas the dsPIC is a 3.3v part. You should be
using the 47L04 since it's a 3.3v part. |
avro698
Joined: 11 Nov 2006 Posts: 9 Location: South Wales, UK.
Posted: Fri May 03, 2019 3:49 am |
I'm using 47L16 at 3.0V without issue.
To clarify, does your hardware have a capacitor on the VCAP pin? (this is needed for autostore function on power removal).
This device has two groups of addresses; one for normal ram access, the other for control.
Normal eeprom actions use device addresses 0xA0/0xA1 (plus whatever value you have for A1 and A0).
Control of the device is via device addresses 0x30/0x31 (plus whatever value you have for A1 and A0).
To get the device to autostore on power removal you need to set the ASE (bit 1) of the STATUS register (Explanation on page 15 of the datasheet you linked to). I believe this is zero by default (the datasheet is not very clear in this regard). This register is non-volatile so you only need to set ASE once.
So to enable autostore something like this is required on the I2c bus; <write command address>,<access status register>,<set ASE bit> or; 0x30,0x00,0x02
Hope that helps.
Regards,
avro698 |
David Pouzar
Posted: Fri May 03, 2019 6:28 am |
Thank you for the help. I am using a i2c at 5 volts.. Yes I have the cap on the board. I am actually using Mikroe board eeram 5v. The problem was fixed by initialize the chip like avro recommended. Thank you.. |
Posted: Sat May 04, 2019 1:44 am |
How?.
Show your I2C setup code, and the wiring you have for the I2C bus.
Understand, that if I2C is being pulled up to 5v, the PIC pins will
be overvoltaged, and be limiting the voltage with their internal protection
diodes, risking the PIC supply being raised and overvoltaging the PIC.
The 47C16 requires Vih to be > 0.7Vcc, so 3.5v. Above the voltage
that can be generated with 3.3v pullups.
This is a combination that really _requires_ a level shifter between
the two busses.
Look at the FET level shifter in this AN:
<https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=13&cad=rja&uact=8&ved=2ahUKEwjo2_b-r4HiAhWlunEKHa_mBKUQFjAMegQIAhAC&url=https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN10441.pdf&usg=AOvVaw2Tvfiswb6hEumO5qUyIgPV>
You _need_ something like this. |
