art
ex_usb_keyboard |
Posted: Tue Apr 30, 2019 7:38 pm |
I'm trying to learn about ex_usb_keyboard example. My problem is I do not have National 960x hardware. Is there is any other way that I can learn it without using National 960x hardware ?
Actually what is National 960x hardware? how does it look like ?
Can I build it by myself?
Please help me. |
Posted: Wed May 01, 2019 1:29 am |
National 960x, is the 'else' in the build for this. Only used if you _don't_
have a USB PIC16, PIC18, or PIC24.
The USBN9602, 3 or 4, is a complete USB interface, allowing USB to be
handled on PIC's that don't support USB directly. |
art
Posted: Wed May 01, 2019 2:21 am |
Oooo..i see. I'm going to use PIC18F4550 to test this example.
Thank you Ttelmah. |
Posted: Wed May 01, 2019 2:37 am |
Good.
If you are not using the demo board, when you get ready to build for the chip,
post up your details (crystal etc.), and we can tell you the fuse settings
needed (the fuse settings for the 4550, are quite complex...).
Remember you need a crystal that is 4MHz, 8MHz, 12MHz, 16MHz, 20MHz or
24MHz, for full speed USB, and on this chip USB cannot be done without
a crystal.
Well done actually for trying to understand the code 'first'. |
