Warning message for DEBUG mode
testman
PostPosted: Mon Apr 22, 2019 3:08 am     Reply with quote
Hello !
I have strange problem with DEBUG mode> Compiler says:
Warning: The hex file has the debug bit set. The debug bit has been cleared during load to memory. The original hex file has not been modified.
I have never enabled debug mode.
I don't have ICD enabled
Can someone tell me what is the problem and how to solve it?
PostPosted: Mon Apr 22, 2019 4:42 am     Reply with quote
sounds like the first time you compiled , the debug bit was set. Could be the 'Wizard', as it's not too smart...
If you're using MPLAB, it's default compilation mode is 'debug'. You need to change to 'release' for a PIC to run right. I set mine to 'release' as the default, problem solved as I never debug within a PC.
You should post what IDE, compiler and programmer you're using.
