John Morley Guest
problem with shift_left..... |
Posted: Mon Jun 23, 2003 11:19 am |
Hi all,
Compiler version: 3.162
I am using shift_left to clock 8 bits of data out of a peripheral device, MSB first. The problem is that when I get the 8th bit, the variable that the data is going into rolls over to a negative number. I seem to be doing it exactly the way numerous examples in the manual do it, but mine has this undesired behaviour. BTW, the data variable is define as:
int data;
I show the routine I am having a problem with first, and then the output of a printf to show what's going on. As you can see from the output, all seems to be well until the 8th bit....
for(ctr = 1 ; ctr <= 8 ; ++ctr)
output_high(SCLK); // Clock to high
delay_us(20);
shift_left(&data,1,input(SDATA));
output_low(SCLK); // Clock to low
printf("ctr, bit, data: : \%i \%i \%i\n\r", ctr,input(SDATA), data);
output_low(SDATA); // Acknowledge the 1st byte to be driven by the SHT1x
output_high(SCLK);
delay_us(20);
output_low(SCLK);
Output:
ctr, bit, data: : 1 1 1
ctr, bit, data: : 2 1 3
ctr, bit, data: : 3 1 7
ctr, bit, data: : 4 0 14
ctr, bit, data: : 5 0 28
ctr, bit, data: : 6 0 56
ctr, bit, data: : 7 0 112
ctr, bit, data: : 8 1 -32
Thanks for looking!
John
___________________________
Original Post ID: 144515473 |
Neutone
Re: problem with shift_left..... |
Posted: Mon Jun 23, 2003 11:25 am |
:=Hi all,
:=Compiler version: 3.162
:=I am using shift_left to clock 8 bits of data out of a peripheral device, MSB first. The problem is that when I get the 8th bit, the variable that the data is going into rolls over to a negative number. I seem to be doing it exactly the way numerous examples in the manual do it, but mine has this undesired behaviour. BTW, the data variable is define as:
:=int data;
:=I show the routine I am having a problem with first, and then the output of a printf to show what's going on. As you can see from the output, all seems to be well until the 8th bit....
:= for(ctr = 1 ; ctr <= 8 ; ++ctr)
:= output_high(SCLK); // Clock to high
:= delay_us(20);
:= shift_left(&data,1,input(SDATA));
:= output_low(SCLK); // Clock to low
:= printf("ctr, bit, data: : \%i \%i \%i\n\r", ctr,input(SDATA), data);
:= output_low(SDATA); // Acknowledge the 1st byte to be driven by the SHT1x
:= delay_us(20);
:=Output:
:=ctr, bit, data: : 1 1 1
:=ctr, bit, data: : 2 1 3
:=ctr, bit, data: : 3 1 7
:=ctr, bit, data: : 4 0 14
:=ctr, bit, data: : 5 0 28
:=ctr, bit, data: : 6 0 56
:=ctr, bit, data: : 7 0 112
:=ctr, bit, data: : 8 1 -32
:=Thanks for looking!
:=John
So the printf function is showing a signed interger instead of an unsigned interger? Verify the printf function call is formatted correctly. If you were shifting in a signed byte it worked fine.
Original Post ID: 144515475 |
Sherpa Doug Guest
Posted: Mon Jun 23, 2003 12:24 pm |
It looks like a printf problem. Try printing the result in hex instead of decimal to see what the actual bits are.
:=Hi all,
:=int data;
:= delay_us(20);
:= delay_us(20);
:=Output:
:=John
Original Post ID: 144515478 |
