RossJ
Disabling UART TX output on a PIC with PPS |
Posted: Mon Nov 19, 2018 2:38 am |
I've just begun using the PIC18LF27K40 which is the first chip I've used with PPS. In my design I have a wireless module which can be powered off completely. Consequently, it's critical not to back power the module through the TX line (which of course idles high).
Previously, I simply enabled/disabled the UART using setup_uart() which controls SPEN which in turn determines whether the USART module has control of the pin.
From what I observe with PPS, whether the pin is controlled by the USART module is strictly determined by PPS regardless of whether the USART module is enabled by SPEN (which makes sense).
The catch though is that the #use_rs232 directive seems to require that the RX/TX pins already be assigned with #pin_select first (even with noinit). I can subsequently use pin_select() to remove the output for TX, but there will be at least a glitch during reset which I'd prefer to avoid.
The only solution I can see is to have #pin_select set the TX pin to another unused/unimportant pin and then change it later. This is a hack. Is there a better way?
Perhaps the noinit option really should cause the compiler check (on pin_select) to be skipped.
/Ross |
Posted: Mon Nov 19, 2018 4:05 am |
What you do, is setup select to a pin temporarily.
Then deselect it.
On output devices, the data is stored on a 'pin' basis. This is why there is a
'NULL' selection offered. So:
#pin_select U1TX=PIN_B1
#pin_select U1RX=PIN_B0
#use RS232(UART1, ERRORS, BAUD=9600)
//setup for boot
//Then in your main:
//deselect U1TX
pin_select("NULL", PIN_B1);
This connects PIN_B1 back to the LATxy device (the standard output...).
It is an 'issue', since as you say it would possibly make sense to have NOINIT, skip the check, but this then leaves you with the possibility of having a device enabled, without it's pins configured. Since this is a 'compile time' check, they want to ensure this cannot happen.
Ideally, they perhaps ought to accept a #PIN_SELECT, set to a 'NULL' pin for a device using NOINIT. Suggest this to CCS. Explain the reason.
Possibly even 'better' would be if #USE RS232 supported just enabling the RX hardware. Given you can't enable the UART and have TX only, but can have RX only by turning off the TXEN bit, it'd be lovely is #USE RS232 had a RX_ONLY option, since this would then remove the problem. |
asmallri
Joined: 12 Aug 2004 Posts: 1634 Location: Perth, Australia
Posted: Mon Nov 19, 2018 9:34 am |
You could always tell the compiler that the UART is enabled by PPS, then in your code when you want the peripheral to go to sleep you manually manipulate the PPS registers to disconnect the UART from the pin. However you will need to use fast/io mode to ensure the LAT output remains low. _________________ Regards, Andrew
Posted: Mon Nov 19, 2018 11:28 am |
Problem is, he is worried about the glitch at boot, when the TX signal drives the pin high, before he takes over control of the pin. |
asmallri
Posted: Mon Nov 19, 2018 2:30 pm |
Ttelmah wrote: | Problem is, he is worried about the glitch at boot, when the TX signal drives the pin high, before he takes over control of the pin. |
Ah, missed that. I had a similar issue for one of my products. I addressed it by using an analog MUX to disconnect the serial interface logic using the same control line that was the power enable for the peripheral. The trick is naturally to ensure the control inputs to the MUX have appropriate pull-up or pull-down resistors so the inputs do not float while the PIC is powering up. The solution worked very well. _________________ Regards, Andrew
RossJ
Posted: Mon Nov 19, 2018 4:13 pm |
Thanks everyone for your input. Looks like the best available option for me is to set the TX up on a dummy output then relocate it as required. Just seems a little clunky.
(I've been running with 5.070 which has bugs in the pin_select() function (but #pin_select is okay) for the PIC18LF27K40 (wrong SFR addresses). I've just renewed my maintenance plan so hopefully it is fixed).
Cheers, Ross |
Posted: Tue Nov 20, 2018 7:54 am |
I would honestly talk to CCS, and suggest that they either allow the hardware UART to be programmed for receive only, or offer the option to bypass the PIN_SELECT testing when NOINIT is used. |
