Is there a way to use I2C lines and then release them so they can be normal I/O lines in the program? I am needing to do some I2C commands then the slave device is putting a pulse out on the SDA line for timing from then on.
MPLAB V 8.91.00.00
CCS PCM C Compiler, Version 5.064, xxxxx
Windows 10
16F876 running on 5V.
Posted: Wed Sep 12, 2018 12:34 pm
This line will disable the hardware i2c module and release SDA and SCL:
