Byeon woo sung
ccp2 pwm |
Posted: Tue Jul 24, 2018 5:50 pm |
I use pic18f65k40.
I would like to get a pwm waveform use ccp2 with rb4 port.
But i can't get waveform. (low signal).
Can you see what's wrong?
Code: | #include <18F65K40.h>
#device ADC = 10
#fuses HS,NOWDT,NOPROTECT,CLKOUT,PPS1WAY
#use delay(clock= 16000000 )
#BYTE PORTE = 0XF8D
#BYTE TRISE = 0XF85
#pin_select CCP2OUT=PIN_E4
int i= 124;
setup_oscillator(OSC_HFINTRC_16MHZ);
setup_adc(ADC_CLOCK_DIV_32);
setup_adc_ports(NO_ANALOGS);
setup_comparator_1(NC_NC);
setup_comparator_2(NC_NC);
setup_comparator_3(NC_NC);
setup_timer_2(T2_DIV_BY_4,250,1);
setup_ccp2(CCP_PWM);
set_tris_e(0x00);
set_pwm2_duty(i);
Posted: Wed Jul 25, 2018 1:08 am |
This line is the problem:
Quote: | setup_timer_2(T2_DIV_BY_4,250,1); |
With the K40 series PICs, you need to specify the clock source as internal:
Code: | setup_timer_2(T2_CLK_INTERNAL | T2_DIV_BY_4, 250, 1); |
Posted: Wed Jul 25, 2018 1:42 am |
Well done PCM_Programmer.
This is one of those 'caveat' ones. On most of the older PIC16/18 PWM's, the clock source for timer2 is fixed (FOSC/4). No choices. If you look at the diagram for the timer, a direct connection. On the K40 and a few other newer PIC's the timer can be operated from other sources. In this case 9 sources. ZCD_OUT, CLKREF_OUT, SOSC, MFINTOSC, LFINTOSC, HFINTOSC, FOSC, FOSC/4, and an external PIN (PPS selectable). The default 'erased' state, selects one of the combinations that is 'reserved', so the timer won't work...
The T2_CLK_INTERNAL settings selects FOSC/4, giving normal operation.
I must admit to having played with PWM's clocked off an external pin, and it is quite a useful ability. |
