PIC24FJ1024GB610 RC13/RC14 I/O control issue
mxie1234
PostPosted: Sun Jul 15, 2018 5:41 pm     Reply with quote
Just found this strange issue. For this chip, PIC24FJ1024GB610 (100-pin TQFP), PortC I/O behaves strange. Among the available portC pins (RC1, 2, 3, 4, 13, 14, RC12 and RC15 are for crystal Osi), RC13 and RC14 are not controllable by command "output_high(PIN_C13)"/"output_low(PIN_C13)", or "output_high(PIN_C14)"/"output_low(PIN_C14)".
However, the other portC pins (RC1,2,3,4) are working fine to toggle with the same commands.
Does anybody see the same issue here ? What is the reason ?
Thanks,
Re: PIC24FJ1024GB610 RC13/RC14 I/O control issue
PostPosted: Sun Jul 15, 2018 6:45 pm     Reply with quote
mxie1234 wrote:
RC13 and RC14 are not controllable by command.
The PIC data sheet (on page 39) labels these pins as SOSCI and SOSCO.
See this thread. Notice the SOSC_DIG fuse and other comments:
http://www.ccsinfo.com/forum/viewtopic.php?t=56252
mxie1234
PostPosted: Sun Jul 15, 2018 8:33 pm     Reply with quote
Thanks a lot, this really helps. Changed to a different I/O.
