Matrix with BIT and location memory
nailuy
PostPosted: Sun May 27, 2018 10:55 am     Reply with quote
Hy.
I have code that is not working properly.
on main.c
if (input(K1)==1){
   BIT_LED();
on 12f509.h
static unsigned int16 DIV_PR;
#locate DIV_PR = 0x30      //and 0x31
static unsigned int8 BUTTON;
#locate BUTTON = 0x32
static unsigned int8 TIME_SEL;
#locate TIME_SEL = 0x33
static int1 DATA_LED[16];
#bit DATA_LED  = 0x34.0
//#bit DATA_LED  = 0x35.0
static unsigned int8 i;
#locate i = 0x36
static unsigned int8 DELAY;
#locate DELAY = 0x37
and lst file
static unsigned int16 DIV_PR; //
004A:  BSF    04.5
004B:  CLRF   10
004C:  CLRF   11
.................... #locate DIV_PR = 0x30
.................... static unsigned int8 BUTTON;
004D:  CLRF   12
.................... #locate BUTTON = 0x32
.................... static unsigned int8 TIME_SEL;
004E:  CLRF   13
.................... #locate TIME_SEL = 0x33
.................... static int1 DATA_LED[16];
004F:  BSF    04.7
0050:  CLRF   00
0051:  CLRF   01
.................... #bit DATA_LED  = 0x34.0
.................... //#bit DATA_LED  = 0x35.0
.................... static unsigned int8 i;
0052:  BCF    04.7
0053:  CLRF   16
.................... #locate i = 0x36
.................... static unsigned int8 DELAY;
0054:  CLRF   17
.................... #locate DELAY = 0x37
and an on another c file
#define ACTIV_LED delay_us(1),(output_bit(OC,1), delay_us(1), output_bit(OC,0))
void BIT_LED(void)
   i=0;
   while (i<18){
      output_bit(OD, DATA_LED[i]);
      ACTIV_LED;
      i++;
The problem is: when I run the program returning different value on DATA_LED[9] is like "1", and all other is "0" as is defined on beginning.
Have someone an idea of what's happening?
PostPosted: Sun May 27, 2018 11:28 am     Reply with quote
I can't actually see 'why' you are #locating most of the things?. Just let them go where they want to go. #locate should only be used to do things like map a variable to one of the SFR's. Moving stuff around otherwise is just asking for problems....
#bit locates a single bit variable at the location defined. It does not say that it can be used to locate an existing variable, To locate the array, use:
#byte DATA_LED  = 0x34
#byte as it's secondary function can locate any already declared variable to a location.
Whether that will work I don't know, but it is more correct than trying to use a #bit definition on the array.
nailuy
PostPosted: Sun May 27, 2018 1:32 pm     Reply with quote
yes Ttelmah you are right.
#word is solution.
#word DATA_LED  = 0x34
Now is working.
Thank you.
