memcpy problem
kmp84
memcpy problem
PostPosted: Thu Mar 29, 2018 9:05 am     Reply with quote
Hello all,
I have a problem with 'memcpy' function. This is a simple test program.
#include <33EP512MU810.h>
#device ICSP=1
#use delay(crystal=8MHz, clock=32MHz)
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NOJTAG                   //JTAG disabled
void main(void){
   int8 src_buff[]={1,2,3,4,5};
   int8 dest_buff[5];
   memcpy(dest_buff, src_buff, 5);
   while(1){
Can't copy source array to destination array. What the problem might be?
Compiler ver.5.075.
PostPosted: Thu Mar 29, 2018 11:33 am     Reply with quote
Report it to CCS.
This has come up before, been fixed, but seems to have reappeared!...
This will work:
#device ICSP=1
void main(void){
   int8 dest_buff[5];
   memcpy(dest_buff, src_buff, 6); //Duh!....
   while(1){
kmp84
PostPosted: Thu Mar 29, 2018 4:05 pm     Reply with quote
I sent more than five email, with similar problems but no answer!
PostPosted: Thu Mar 29, 2018 4:28 pm     Reply with quote
You must have patience ! They WILL get back to you it may take a day or two, depending on how busy they are with other clients and code.
In the meantime, perhaps you can try an earlier version of the compiler and see when the bug appears? That will narrow down the problem.
Jay
PostPosted: Fri Mar 30, 2018 12:44 am     Reply with quote
It was in compilers years ago, and reported here.
It was then fixed, and appears it must have come back....
However the simple workround is to just do one byte more as I show. Ideally something like:
#define MEMCPY_FIX(x) (x+1)
//used like
memcpy(dest_buff, src_buff, MEMCPY_FIX(5));
Then when the fix appears, you can just replace the define with 'x' instead of 'x+1', and don't have to change anything else in your code.
kmp84
PostPosted: Fri Mar 30, 2018 7:19 am     Reply with quote
Hi, Smile
There is another problem with memcpy function. This code does not work properly.
#device ICSP=1
#FUSES NOPROTECT
#pin_select U3RX=PIN_G12   // Rx Com3.
#pin_select U3TX=PIN_G13   // Tx Com3.
#use rs232(UART3,baud=115200,errors)
void test_func(int8 *OutBuff){
   int8 s_buff[] = {0,0,0,70,0};
   memcpy(OutBuff, s_buff, 6);
void main(void){
   int8 d_buff[] = {0,0,0,0,0,0};
   test_func(d_buff);
   while(1){
P.S I sent two mails to CCS support before one or more months, but no answer.
