Pic does not send signal to servos
Rodrigo
PostPosted: Mon Feb 26, 2018 11:28 pm     Reply with quote
I'm new to this, I would like some help. I'm making a robot arm with servos. It should have the position set by entering the degree of movement from a 4x4 matrix keyboard. The degrees should be displayed on an LCD.
I have a problem because the entered degrees are displayed on the lcd, but the pic does not output to the servos.
I am using a PIC18F4550.
I hope I have your help, I post my code below...
#include <18f4550.h>
#device ICD = TRUE
#device ADC=10
#use delay (clock=48000000)
#use i2c(Master,Fast=100000, sda=PIN_D6, scl=PIN_D7,force_sw)
#include <i2c_Flex_LCD.h>
#include <kb4x4.h> //LIBRERIA DE TECLADO
#fuses HSPLL,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,USBDIV,PLL5,CPUDIV1,DEBUG,ICSP1 // configura fuses
#USE FAST_IO(B)
#byte trisb=0x86
#byte portb=0x06
#byte trisc=0x87
#byte portc=0x07
#define use_portb_kbd TRUE             //Configuración puerto b control teclado
#bit  Bit_PWM0 =  PORTC.0              //Bit 0 puerto C Salida modulación 0
#bit  Bit_PWM1 =  PORTC.1              //Bit 1 puerto C Salida modulación 1
#bit  Bit_PWM2 =  PORTC.2              //Bit 2 puerto C Salida modulación 2
#bit  Bit_PWM3 =  PORTC.3              //Bit 3 puerto C Salida modulación 3
#bit  Bit_PWM4 =  PORTC.4              //Bit 4 puerto C Salida modulación 4
#bit  Bit_PWM5 =  PORTC.5              //Bit 5 puerto C Salida modulación 5
#bit  Bit_PWM6 =  PORTC.6              //Bit 6 puerto C Salida modulación 6
#bit  Bit_PWM7 =  PORTC.7              //Bit 7 puerto C Salida modulación 7
/********************** Prototipos de las funciones ***************************/
void main (void);             //función principal
void generacion_pwm (void);   //genera señales moduladas para control de servos
void presentacion (void);     //mensaje de presentación
/********************** Variables para generación PWM *************************/
int8 PWM0=0,PWM1=0,PWM2=0,PWM3=0,PWM4=0,PWM5=0,PWM6=0,PWM7=0; //Valores de las señales PWM
int8 control_PWM=0;
/******************* FUNCIÓN GENERACIÓN MODULACIONES PWM **********************/
#int_Timer0
void generacion_pwm(){
   control_PWM++;                //Incremento cada rebose del timer0
   if (control_PWM==0){          //inicio del ciclo con todos los pulsos pwm a 1
      Bit_PWM0=1;
      Bit_PWM1=1;
      Bit_PWM2=1;
      Bit_PWM3=1;
      Bit_PWM4=1;
      Bit_PWM5=1;
      Bit_PWM6=1;
      Bit_PWM7=1;
   //Finalizará el pulso de modulación según el valor del correspondiente pwm
   if (control_PWM==PWM0) Bit_PWM0=0;
   if (control_PWM==PWM1) Bit_PWM1=0;
   if (control_PWM==PWM2) Bit_PWM2=0;
   if (control_PWM==PWM3) Bit_PWM3=0;
   if (control_PWM==PWM4) Bit_PWM4=0;
   if (control_PWM==PWM5) Bit_PWM5=0;
   if (control_PWM==PWM6) Bit_PWM6=0;
   if (control_PWM==PWM7) Bit_PWM7=0;
   set_timer0(255);                    //Carga del contador
/************************* PRESENTACIÓN LCD ***********************************/
void presentacion (){
   lcd_clear();  //Clear Display
   printf(LCD_PUTC,"\1%s","Introduce");
   printf(LCD_PUTC,"\2%s"," num. de servo ");
/******************** FUNCIÓN PRINCIPAL ***************************************/
void main(){
  set_tris_c(0b00000000);  // Configura PIN_C1 como salida
   int x;                        //Valor ASCII de la tecla pulsada
   int tecla;                    //Valor numérico de la tecla pulsada
   int servo;                    //Número de servo
   int16 angulo;                 //Ángulo del servo
   int16 centenas;               //variable para las centenas del ángulo
   int decenas,unidades;         //Variable para las decenas y unidades del ángulo
   int pwm;                      //valor de la modulación por teclado
   trisc=0x00;                   //Puerto C como salida de datos
   pwm0=7;                      //Impulso de 0,8 msg de pwm0 posición 0º
   pwm1=7;                      //Impulso de 0,8 msg de pwm1 posición 0º
   pwm2=7;                      //Impulso de 0,8 msg de pwm2 posición 0º
   pwm3=7;                      //Impulso de 0,8 msg de pwm3 posición 0º
   pwm4=7;                      //Impulso de 0,8 msg de pwm4 posición 0º
   pwm5=7;                      //Impulso de 0,8 msg de pwm5 posición 0º
   pwm6=7;                      //Impulso de 0,8 msg de pwm6 posición 0º
   pwm7=7;                      //Impulso de 0,8 msg de pwm7 posición 0º
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_32);         //Configuración interrupción generación PWM
   enable_interrupts(INT_TIMER0);    //Habilitación interrupción generación pwm
   enable_interrupts(GLOBAL);        //Habilitación de las interrupciones
   port_b_pullups(TRUE);   //Habilitación resistencias pullups puerto b
   lcd_init();             //Inicialización del lcd
   kbd_init();             //Inicialización del teclado
   presentacion ();        //Muestra mensaje de inicio en lcd
   while (true){
      x=kbd_getc();                    //En "x" valor ASCII de la tecla pulsada
      if (x!=0&&x!='9'&&x!='8'&&x!='*'&&x!='#'){ //Si se pulsa tecla numérica 0 a 7 ...
         servo=x-48;            //Valor ASCII se pasa a valor numerico de servo
         printf(lcd_putc,"\fServo = %d\n", servo); //...muestra el valor pulsado
          printf(LCD_PUTC,"\2%s","introduce angulo");
         while (x!='*'){            //Espera a introducir ángulo y aceptar con *
            x=kbd_getc();
            tecla=x-48;
            if (x!=0&&x!='*'&&x!='#'){    //Solo se toman los valores numéricos
               //A cada tecla pulsada se desplaza posición decimal y se muestra
               centenas=decenas;
               decenas=unidades;
               unidades=tecla;
               printf(lcd_putc,"\f Angulo = %ld%d%d\n", centenas, decenas, unidades);
                printf(LCD_PUTC,"\2%s","* para aceptar");
       angulo=(centenas*100)+(decenas*10)+unidades;
       if (angulo>180) angulo=180;    //No acepta valores >180º
       pwm=(angulo/13)+7;             //Ajuste modulación en función del valor introducido
       centenas=decenas=unidades=0;
       //Según número de servo introducido se le aplica el ángulo elegido
       switch(servo){
       case 0: pwm0=pwm; break;
       case 1: pwm1=pwm; break;
       case 2: pwm2=pwm; break;
       case 3: pwm3=pwm; break;
       case 4: pwm4=pwm; break;
       case 5: pwm5=pwm; break;
       case 6: pwm6=pwm; break;
       case 7: pwm7=pwm; break;
       printf(lcd_putc,"\fServo  %d\n", servo);
       printf(lcd_putc," Angulo  %ld", angulo);
       delay_ms(200);
       presentacion();
Roy
PostPosted: Tue Feb 27, 2018 2:04 am     Reply with quote
First thing:
#byte trisb=0x86
#byte portb=0x06
#byte trisc=0x87
#byte portc=0x07
These are all wrong. The values you have are for a PIC16, not a PIC18. This is why we always say 'use the register names':
#byte trisb=getenv("SFR:TRISB")
etc..
So the code is not going to work.
Then there is a problem with your timer interrupt. The timer is running in 16bit mode. So it'll count from 255 (which you set it to in the interrupt), to 65535, then interrupt at 65536 (0). So 65281 counts. The timer is running off Fosc/(4*32) 375000Hz, so will interrupt every 375000/65281 = 5.744* per second. Going to be over a second pulse at a count of 7.....
If you were running in 8bit mode, much faster, but it'll almost certainly never then get out of the interrupt. Just one count of 32 machine cycles between interrupts... :(
If '7' is meant to be the zero degree output (1mSec), then you want an interrupt at 143uSec. 1714 counts of the Fosc/4 feeding the timer. Using /32, 53 counts. So:
   setup_timer_0(T1_INTERNAL|T0_DIV_32|T0_8_BIT);
   //select 8bit mode
   //for the timer setup, and then:
   set_timer0(203);
   //to make it trigger at the interval required
Should give about the right timing.
Rodrigo
Ayuda...
PostPosted: Tue Feb 27, 2018 1:55 pm     Reply with quote
Friend, I have already modified the register names and it still does not output to the servos.
Could you explain to me more, or help me with the code in the timer part?
Thank you!!!
Roy
guy
PostPosted: Fri Mar 02, 2018 1:29 pm     Reply with quote
Hola Rodrigo.
Start by checking that the registers and setup are correct - send 1ms pulse every 20ms to one servo (no interrupts):
output_high()
delay_ms(1)
output_low()
delay_ms(19)
If the setup is working ok you can debug the timer and logic easily with an oscilloscope.
