ubuntuman
Two PIC 18f4620, 1 as master & 2nd is slave I2C problem |
Posted: Wed Nov 15, 2017 5:54 am |
The complete Master code. HS oscillator mode 4MHz.
const long int crystalOscillator =4000000;
unsigned short int temp=0;
void I2C_Master_Init(const unsigned long int c)
SSPCON1 = 0b00101000;
SSPCON2 = 0;
SSPADD = (crystalOscillator/(4*c))-1;
SSPSTAT = 0b11000000;
TRISC.B3 = 1; //Setting as input as given in datasheet
TRISC.B4 = 1; //Setting as input as given in datasheet
void I2C_Master_Wait()
while ((SSPSTAT & 0x04) || (SSPCON2 & 0x1F));
void I2C_Master_Start()
I2C_Master_Wait();
SSPCON2.SEN = 1;
void I2C_Master_RepeatedStart()
I2C_Master_Wait();
SSPCON2.RSEN = 1;
void I2C_Master_Stop()
I2C_Master_Wait();
SSPCON2.PEN = 1;
void I2C_Master_Write(unsigned short int d)
I2C_Master_Wait();
SSPBUF = d;
unsigned short int I2C_Master_Read(unsigned short int a)
unsigned short int temp;
I2C_Master_Wait();
SSPCON2.RCEN = 1;
I2C_Master_Wait();
temp = SSPBUF;
I2C_Master_Wait();
if(a==1){SSPCON2.ACKDT=1;}
else{SSPCON2.ACKDT=0;}
SSPCON2.ACKEN = 1;
return temp;
I2C_Master_Init(100000); //Initialize I2C Master with 100KHz clock
//I2C1_Init(50000);
OSCTUNE.PLLEN=0;
Delay_ms(500);
TRISB=0;
PORTB=0;
I2C_Master_Start();
I2C_Master_Write(0xAA); //Write data
//I2C_Master_Write(0x00);
I2C_Master_Stop();
Delay_ms(5000);
The complete Slave code . HS oscillator mode .4MHZ
unsigned short int zed=0;
volatile unsigned short int new =0 ,dataRead=0 , dataWrite=0;
unsigned char dataReadCh[7] , dataWriteCh[7];
void interrupt()
if(PIR1.SSPIF == 1)
SSPCON1.CKP = 0;
new=1;
zed = SSPBUF;
PIR1.SSPIF = 0;
SSPCON1.CKP = 1;
if ((SSPCON1.SSPOV) || (SSPCON1.WCOL))
zed = SSPBUF; // Read the previous value to clear the buffer
SSPCON1.SSPOV = 0; // Clear the overflow flag
SSPCON1.WCOL = 0; // Clear the collision bit
SSPCON1.CKP = 1;
if(!SSPSTAT.D_A && !SSPSTAT.R_W)
while(!SSPSTAT.BF){};
while(SSPSTAT.BF){dataRead = SSPBUF;}
SSPCON1.CKP = 1;
else if(SSPSTAT.D_A && SSPSTAT.R_W)
while(SSPSTAT.BF){zed = SSPBUF;}
SSPBUF = dataWrite ;
SSPCON1.CKP = 1;
while(SSPSTAT.BF){};
PIR1.SSPIF = 0;
void I2C_Slave_Init(unsigned short int address)
SSPADD = address;
SSPCON1 = 0b00110110;
SSPCON2 = 0b00000001;
//TRISC.B3 = 1; //Setting as input as given in datasheet
//TRISC.B4 = 1; //Setting as input as given in datasheet
TRISC=0b00011000;
LATC= 0b00011000;
INTCON = 0b00000000;
INTCON.PEIE = 1;
INTCON.GIE = 1;
PIE1.SSPIE = 1;
PIR1.SSPIF = 0;
while(SSPSTAT.BF){zed = SSPBUF;SSPCON1.SSPOV = 0;SSPCON1.WCOL = 0;}
OSCTUNE.PLLEN=0;
ADCON1=0b00001111;
TRISA.B0 = 0; //PORTD as output
PORTA.B0=0;
I2C_Slave_Init(0xAA); //Initialize as a I2C Slave with address 0x30
if(new==1)
PORTA.B0=1;
new=0;
The problem is each time I send 0xAA from the master to the slave after putting 0xAA to slave SSPADD, I get NOTACK signal. I don't know where is the thing who doesn't work.
Here you are, screenShot for the WaveForm i get https://imgur.com/2VGF4Gk
Joined: 01 Jul 2010 Posts: 9205 Location: Greensville,Ontario
Posted: Wed Nov 15, 2017 6:34 am |
quick comments
1. Doesn't look like CCS C code. CCS supply easy to use I2C functions
2. No PIC device header as 1st line of code, can't cut/paste, no fuses?
3. With ANY I2C program, run I2C Scanner program from code library |
Posted: Wed Nov 15, 2017 6:43 am |
It's for the MikroC compiler. Not CCS. |
ubuntuman
Posted: Wed Nov 15, 2017 7:21 am |
PCM programmer wrote: | It's for the MikroC compiler. Not CCS. |
Right but the problem is not in compilers. It is in the pic 18f4620 settings and in the MSSP hardware register settings so if you have any working code for 18f4620 master/slave written in any language, pass it pls to me. |
Posted: Wed Nov 15, 2017 7:45 am |
We won't have anything you can use. CCS has built-in functions to do
all the i2c setup and bus transactions. We don't have to write to PIC
registers to make something work.
For example, you've got this as your setup code in MikroC:
SSPCON2 = 0;
We would write something like:
Code: | #use i2c(Master, I2C1) |
and that would handle all the setup.
Another example. This is how you do a start in MikroC.
Code: | void I2C_Master_Start()
I2C_Master_Wait();
SSPCON2.SEN = 1;
This is how we do it in CCS.
See, our way of coding won't help you. You need to go to a MikroC forum. |
Posted: Wed Nov 15, 2017 8:55 am |
re:
Quote: | See, our way of coding won't help you. You need to go to a MikroC forum. |
It'd be better to just buy the CCS compiler !!
His project could be up and running in an hour or so....
AND
then we could help him...
