code question
soonc
code question
PostPosted: Thu Aug 31, 2017 4:09 pm     Reply with quote
Recently I've been using the mmcsd.c library code to directly write to a 2GB SD card.
It's working.
During my debugging sessions I ran in this line of code:
for(i = 0; i < MMCSD_MAX_BLOCK_SIZE; i += 1)
my question why use i += 1 when i++ will produce less code ?
....................    for(i = 0; i < MMCSD_MAX_BLOCK_SIZE; i += 1)
0B18A:  CLR     1AE2
0B18C:  MOV     1AE2,W4
0B18E:  MOV     #200,W3
0B190:  CP      W3,W4
0B192:  BRA     LEU,B1B0
....................       MMCSD_SPI_XFER(ptr[i]);
0B194:  MOV     1AE2,W0
0B196:  ADD     1ADC,W0
0B198:  MOV.B   [W0],W5L
0B19A:  MOV     #0,W1
0B19C:  MOV     #8,W2
0B19E:  MOV.B   W5L,W0L
0B1A0:  CLR.B   1
0B1A2:  CALL    312C
0B1A6:  MOV     1AE2,W4
0B1A8:  ADD     W4,#1,W0
0B1AA:  MOV     W0,1AE2
0B1AC:  GOTO    B18C
....................    for(i = 0; i < MMCSD_MAX_BLOCK_SIZE; i++)
0B18A:  CLR     1AE2
0B18C:  MOV     1AE2,W4
0B18E:  MOV     #200,W3
0B190:  CP      W3,W4
0B192:  BRA     LEU,B26C
0B194:  MOV     1AE2,W0
0B196:  ADD     1ADC,W0
0B19A:  MOV     #0,W1
0B19C:  MOV     #8,W2
0B1A0:  CLR.B   1
0B1A2:  CALL    312C
PostPosted: Thu Aug 31, 2017 5:00 pm     Reply with quote
All programmers have their style of cutting code. This code cutter uses what he either was taught or found to work for him.
You can program either for smaller code( saves memory) or for speed of execution.
Perhaps his code does execute faster, I don't know. What we do know is his code does work !!
Jay
PostPosted: Thu Aug 31, 2017 6:39 pm     Reply with quote
I just did a text search of the \Examples and \Drivers folders for "i += 1".
It's used 2x in mmcsd.c and 12x in fat.c, and in no other files.
oxo
PostPosted: Fri Sep 01, 2017 12:26 am     Reply with quote
Be thankful it's not i = i + (int8)1;
:D
