help
NAVID
help
PostPosted: Mon Aug 28, 2017 10:03 am     Reply with quote
hi every one
I want to send characters to pic 16f877a by hc-05 and i do this correctly. Then i want to when pic receive "^" show characters but it does not work.
I don't know why but i hope somebody can help me. This is my program:
#include <main.h>
#include "lcd_flex.c"
#include <string.h>
int1 b=0,step=0;
int8 rec,a[11];
char c[1]='^';
//char d[1];
#INT_TBE
void  TBE_isr(void)
#INT_RDA
void  RDA_isr(void)
for(rec=0;rec<10;rec++){
a[rec]=getc();
 if(strcmp(c,a[rec])==1){
  step=1;} }
 step=1;
  // enable_interrupts(INT_TBE);
   enable_interrupts(INT_RDA);
   if(b==0){
     lcd_gotoxy(1,1);
     lcd_putc("hi lets start");
     lcd_clear();
     b=1;}
 if(step==1){
     lcd_clear();
     lcd_gotoxy(1,1);
     printf(lcd_putc,"%s             ",a);
     step=0; }
Exclamation Question
PostPosted: Mon Aug 28, 2017 10:13 am     Reply with quote
this line...
says IF the a[rec] value is equal to the value of variable c, then do something.
However you've got an ARRAY called C, not a simple variable called C.
It should work though, as
if(strcmp(c(0),a[rec])==1){
providing the FIRST array location is C(0) and not c(1).
Really the 'test variable' ("^") should be just a character variable perhaps named caret.
There are other problems in your code.
For one, do not use the xmt ISR, not really needed.
The receive ISR only fires on ONE incoming character.
I suggest you look at the CCS supplied example program call ex_sisr.c in the 'examples' folder for how to receive a 'string' of characters.
NAVID
PostPosted: Mon Aug 28, 2017 11:18 am     Reply with quote
Thank you, I will go to look at the example and come back to ask some questions later ((:
NAVID
PostPosted: Tue Aug 29, 2017 11:14 am     Reply with quote
hi again
what is the xmt ISR ??
PostPosted: Tue Aug 29, 2017 2:15 pm     Reply with quote
this ....
#INT_TBE
void TBE_isr(void)
...is the xmt ISR ( transmit ISR )
It's only 5 lines of code, not being used in your program so just delete it.
ezflyr
PostPosted: Thu Aug 31, 2017 1:29 pm     Reply with quote
It hasn't been mentioned yet, but your Rx interrupt (#INT_RDA) construct is totally wrong. The serial interrupt fires for each character that is received, so you should read one - and only one - character inside the ISR. Put these characters inside an array, and process the array in Main() once the entire transmission is received. Don't read multiple characters inside the ISR!
John
NAVID
PostPosted: Sat Sep 02, 2017 11:19 pm     Reply with quote
ezflyr wrote:
Hi, thanks.
So what i must going to do??
Can you write for me an example??
PostPosted: Sun Sep 03, 2017 1:19 am     Reply with quote
ex_sisr.c, shows how a serial receive routine should be done.
There have also been lots of examples here.
