guy
ICD-U64 & PIC16F18855 (also posted in the CCS ICD forum) |
Posted: Tue Jul 25, 2017 2:21 am |
Has anyone tried to debug with ICD-U64 & PIC16F18855 ?
I've been having trouble and I'm not sure if it has to do with my equipment or a CCS issue. |
Posted: Tue Jul 25, 2017 2:56 am |
I had problems with a PIC24FJ512GB606. Another similarly 'new' chip.
First, check what version firmware you have in the ICD, and try updating to the latest if you haven't already got this. Also, what compiler version?. Apparently there are some changes in the IDE that also affect handling for the latest chips (this was a problem for me, as 5.072/3 introduced a problem with the PIC24, which was not there in 5.070 - touch wood, 5.074 seems to have this fixed).
If you still have the problem with the latest firmware and IDE, then talk to CCS. They sent me a beta firmware, which at present is working OK. |
guy
Posted: Tue Jul 25, 2017 3:00 am |
Hi Mr. T.
Did you switch to CCS ICD?!
I've been in contact with them, also tried the beta firmware, 5.074 etc. but no luck so far. |
Posted: Tue Jul 25, 2017 3:09 am |
I have a number of debuggers. Pickit3, ICD-U40, ICD-U64, ICD2, ICD3, and Mach-X (run as a debugger). Currently this latter is the one that works reliably!...
The Pickit3 works from MPLAB-X, but the package gives problems everywhere.
This debugger hangs intermittently if used from the CCS IDE.
The CCS ICD-U40, and the MicroChip ICD2, don't support this chip.
The U64, run from MPLAB crashes. Run from the CCS IDE, it works, but intermittently hangs when programming the chip. However 90% of the time it is OK.
Mach-X works from the CCS IDE, and has been fine.
Switch down to an older chip, and the crashes/hangs disappear. |
guy
Posted: Tue Jul 25, 2017 3:43 am |
This is a useful review for many folks! Although it might not be pinned on the top of the forum
Still waiting to hear if someone got the 16F18855 to work with one of CCS's debuggers?? |
Posted: Tue Jul 25, 2017 12:44 pm |
What is your unit actually doing?.
One thing I found, was I had to shorten the supplied cable. The new chips support much faster programming algorithms than the older units, and the original cable (about 150mm), was causing noticeable signal degradation. I made one as short as I could (only about 75mm), and things improved noticeably when this was used.... |
guy
Posted: Sun Aug 20, 2017 5:22 am |
CCS managed to fix the problem mostly and it will be incorporated in the next version. I think the situation now is like you describe Ttelmah - the debugger works but will occasionally lose comm.
I hate shortening the RJ11 cable since 6-wire RJ11s are hard to come by... I might cut it in one of my rage bursts if the debugger needs restarting |
