Checking battery voltage with A/D
Newbie
PostPosted: Wed Oct 19, 2005 1:25 pm     Reply with quote
Can I monitor the battery supply (VCC) with the A/D on a PIC? is it a good way to determine the voltage level?
Anyone done this before and got circuit / advice?
Mark
PostPosted: Wed Oct 19, 2005 1:38 pm     Reply with quote
Yep, and someone posted a method very recently where the Vref was set so that as the voltage dropped, the A/D reading got higher.
newguy
PostPosted: Wed Oct 19, 2005 1:54 pm     Reply with quote
....and here it is.
http://www.ccsinfo.com/forum/viewtopic.php?t=24560&start=0
Newbie
First thank....now?
PostPosted: Wed Oct 19, 2005 3:30 pm     Reply with quote
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Wed Oct 19, 2005 4:45 pm     Reply with quote
Newbie wrote:
OK, because my circuit is running at 3.6v can I use the configuration shown here to enable / disable the voltage divider?
http://www.ccsinfo.com/forum/viewtopic.php?p=49830
The circuit, which is originally shown in that conversation will not work for a battery voltage higher then the PIC's Vcc. The reason is described in the second post of that thread.
If the battery voltage is lower then the PIC's Vcc, you can mweasure it directly without a voltage divider and a loss associated with it. EDIT: This can happen only if your Vcc is generated by a step-up converter from the Vbat.
If your PIC is powered directly from the battery without a regulator (EDIT: Vbat = Vcc), you can do the voltage reference trick mentioned above.
Newbie
Brilliant
PostPosted: Wed Oct 19, 2005 5:48 pm     Reply with quote
So as I am powering the entire circuit from a battery, the same battery I want to monitor I can simply connect VCC to the A/D input and do read to determine the battery voltage?
What sort of resolution will I get this a 10bit A/D?
Sorry if I appear a bit thick but I am new and learning.
Thx
kender
Re: Brilliant
PostPosted: Wed Oct 19, 2005 5:58 pm     Reply with quote
If you connect Vcc to the input of the 10-bit A/D, you will be reading the same valude all the time - 1023 - independent of the battery voltage (or anything else for that matter).
Newbie
OK
PostPosted: Wed Oct 19, 2005 7:20 pm     Reply with quote
Hi again, thought I found a really nice simple answer then, dam Very Happy
OK whats the best way then? I am powering the PIC from a battery (3.6v) and I want to measure the voltage to ensure it does not drop below 3.41v is there a simple way?
Could I do a voltage divider (with enable/disable like in post) and make it 1v below VCC so I would be looking for 2.41v?
Thx
kender
Re: OK
PostPosted: Wed Oct 19, 2005 7:44 pm     Reply with quote
Newbie
PostPosted: Thu Oct 20, 2005 2:30 am     Reply with quote
OK, is it better to use a particular diode, say a precision one or thermally stabilized one (if there such a thing)
Thx
PostPosted: Thu Oct 20, 2005 2:59 am     Reply with quote
Yes. A 'bandgap reference diode', will give a greater accuracy, but for cost/performance, it is hard to beat a TL431 regulator. You connect it's 'ref' output to the A/D input as shown, and the anode to the digital output via a resistor. You want something close to 1mA flow through this when the output is high (so for the 3.6v, something like 1000R does nicely). Switch it on, by raising the digital signal, wait about 30uSec, to allow verything to stabilise, and charge the capacitor in the ADC, read the ADC, and switch the circuit off. The reading will relate to the supply voltage as:
(Value read/1023)*2.5 =Vdd
Newbie
PostPosted: Thu Oct 20, 2005 4:42 am     Reply with quote
Hi Ttelmah,
Do I still need the CAP id I use a TL431?
Newbie
PostPosted: Thu Oct 20, 2005 5:04 am     Reply with quote
Hi again Ttelmah, more questions (told you I am new)
Do I still need the CAP if I use a TL431?
You state "1000R" is that a typo or is it just a 1K in Ohms also will a standard 5% 0.125w do or is a better spec resistor going to improve things
Thx for all your help
newguy
PostPosted: Thu Oct 20, 2005 6:34 am     Reply with quote
The cap can't hurt things if you leave it in.
"1000R" is STANDARD in the electronics field. It means 1,000 ohms. If you see "4R7" that means 4.7 ohms. As for the rating of the resistor (power & tolerance), figure it out. It's not hard.
If your voltage reference is 1.5V, and your battery voltage is 3.6V, then you're going to have a voltage drop of 2.1V across the resistor, right? So, (2.1V)^2/1000 ohms = xxx Watts. Figure it out.
And the tolerance? Will anything be "hurt" if the 1000 ohm resistor is actually 980 ohms? Or 1,040 ohms? Figure it out.
abas.ghorbani
Best And Simple Result
PostPosted: Fri Jul 07, 2017 11:34 pm     Reply with quote
When I checked Kender circuit, i could not get the result.
But I reverse the Zener diode direction and it worked.
The zener voltage becomes into 0.7v and fixed.
And the resistor value was 100 Ohm.
