I'm trying to understand EX_EXTEE.C example. If i'm going to use 24LC256 eeprom, what is the last address location that i can write in? is it FFFF ? Where should i refer this information?
Posted: Fri May 12, 2017 10:44 pm
It wants the address to be typed in hex. Look at the 24LC256 data sheet
(find with Google), and it shows the size of the eeprom is 32768 bytes.
So the hex address range will be 0 to 7FFF.
