mcafzap
Joined: 07 Sep 2003 Posts: 46 Location: Manchester, UK
Memory allocation error? |
Posted: Sun Jun 15, 2003 5:22 am |
MPLAB 6.22 & PCH 1.48 & PIC18F252
When I alter the size of an int8 array, the memory usage seems to be double what I expect i.e. increasing the declaration of the index by one causes the compiler to report back an extra 2 bytes used. This is a fairly large program using a large amount of the RAM space (1200 bytes in declarations), about 12 int8 arrays and one 2 dimensional int8 array. However, I need to use more RAM and I rapidly run out...
If I try to replicate the problem with a very simple program the error does not occur.
For commercial reasons I cannot post the whole program, so what I'm really asking is; has anyone else seen a similar problem and have any work-arounds? Or am I doing something really stupid?
Steve
___________________________
Original Post ID: 144515257 |
R.J.Hamlett Guest
Re: Memory allocation error? |
Posted: Sun Jun 15, 2003 2:47 pm |
:=MPLAB 6.22 & PCH 1.48 & PIC18F252
:=When I alter the size of an int8 array, the memory usage seems to be double what I expect i.e. increasing the declaration of the index by one causes the compiler to report back an extra 2 bytes used. This is a fairly large program using a large amount of the RAM space (1200 bytes in declarations), about 12 int8 arrays and one 2 dimensional int8 array. However, I need to use more RAM and I rapidly run out...
:=If I try to replicate the problem with a very simple program the error does not occur.
:=For commercial reasons I cannot post the whole program, so what I'm really asking is; has anyone else seen a similar problem and have any work-arounds? Or am I doing something really stupid?
:=Steve
There can be/are problems with very large arrays. Look in the history of this board, for some examples. Generally, if going significantly above the number of entries supported on the smaller chips (128), it is worth considering manually allocating the storage yourself.
One obvious comment, is that the two dimensional array, will (of course), increase memory useage by the size of the other index for every extra value added.
Original Post ID: 144515262 |
mcafzap
Posted: Sun Jun 15, 2003 4:16 pm |
Thanks for your input RJ.
I'm well aware of the limitations of the PIC family but rather hoped those were behind us with the advent of the 18 series, perhaps not. As I said, I tried a simpler program with only one variable, an int8 multi-dimensional, and the memory allocation was OK, but the fault seems to occur once a certain number of variables is exceeded - the problem is really that I can't so far replicate the fault with a simpler program, nor can I remove it by editing the real program. I'll keep hacking away for a while, then I will probably dive into self-allocation to expedite matters.
Steve
Original Post ID: 144515264 |
TSchultz
Joined: 08 Sep 2003 Posts: 66 Location: Toronto, Canada
RE: Re: Memory allocation error? |
Posted: Mon Jun 16, 2003 7:18 am |
:=Thanks for your input RJ.
:=I'm well aware of the limitations of the PIC family but rather hoped those were behind us with the advent of the 18 series, perhaps not. As I said, I tried a simpler program with only one variable, an int8 multi-dimensional, and the memory allocation was OK, but the fault seems to occur once a certain number of variables is exceeded - the problem is really that I can't so far replicate the fault with a simpler program, nor can I remove it by editing the real program. I'll keep hacking away for a while, then I will probably dive into self-allocation to expedite matters.
:=Steve
I completed a project using a PIC18F452 and encountered very strange memory allocations with large arrays. After revieiwing the memroy assignments I found that the compiler was actuall incorrectly assigning some memroy areas. There were usually problems at the end of arrays, where other variables would be assigned the same locations. I also found some issues with arrays that crossed each of the 256 markers. These problems ocurred once I used more than half the available memory if my memory serves me correctly.
At first I thought it was a problem with arrays of structures, however after recoding everything to use a series of single dimensional arrays the problems still persisted.
These problems were not always ocurrring and were driving me crazy trying to debug my code. I finally resored to reserving most of the memory and manually assigning the locations for all the arrays and data structures.
After manually locating all my variables, I left the lower 128 bytes avialble to the compiler and reserved everything else, I was able to make code and memory structure changes without the strange errors I was encountering before. The only big problem is to remember to update the memory assignments if you change any of the arrays or structures, or variable types.
It is rather unfortunate I had to resort to this, automatic assignments was one of the things the compiler is supposed to do for us.
This may, or may not, be the cause of your problems however I would suggest you review all the memory assingments to make sure they are OK after each compile, especially if you see any strange behaviour.
Best of luck
-Troy
Original Post ID: 144515294 |
mcafzap
Re: RE: Re: Memory allocation error? |
Posted: Tue Jun 17, 2003 1:36 am |
Thank-you, Troy. I did exactly what you did, manually assigned the variables and my 'out of of memory' problems disappeared too.
As you say, it's a pity the compiler has errors in this area. We can live with limitations as long as we know about them.
Steve
Original Post ID: 144515315 |
R.J.Hamlett Guest
Posted: Tue Jun 17, 2003 3:29 am |
:=Thank-you, Troy. I did exactly what you did, manually assigned the variables and my 'out of of memory' problems disappeared too.
:=As you say, it's a pity the compiler has errors in this area. We can live with limitations as long as we know about them.
:=Steve
Yes. If you look back at the previous threads about this, you will find that this is the 'general' solution, for anything using much more than the old 128byte limit. It is an area, where the compiler has for a long time, 'claimed' to offer support for larger sizes, but still seems to have problems several months latter... :-(
Original Post ID: 144515317 |
