Remote data transfer TWS-434 and RWS-434
Goto page 1, 2, 3  Next
young
PostPosted: Mon Nov 29, 2004 8:59 am     Reply with quote
I am trying to use TWS-434 & RES-434 to transfer data and receive data. My setup is like this:
Send data from PC to Transmitter TWS-434,
Setup a PIC (12f675) to receive data from RES-434
Data transferring without TWS & RES was done successfully and being check up on hyperterminal.
I directly connected PC RS232 output pin to TWS pin2 (data in pin), and signal from RES_434 pin 2 connected to MAX232 in pin, max232 out pin was connected to 12f675 data in pin.
right now, without doing anything, 12f675 is receiving garbbage data continuously?
my code is as follows:
#if defined(__PCM__)
#include <12F675.h>
#fuses XT, BROWNOUT,NOWDT,NOPROTECT,PUT,NOMCLR
#use delay(clock =4000000)
#use rs232(baud=2400, parity=N, RCV=PIN_A3,XMIT=PIN_A2)
void main ()
  char ch;
  SETUP_ADC_PORTS(NO_ANALOGS);
        output_high(PIN_A0);
        delay_ms(200);
        output_low(PIN_A0);
        delay_ms(200);
        ch=getchar();
        putc(ch);
       if(ch=='a')
        output_high(PIN_A1);
        delay_ms(200);
        output_low(PIN_A1);
        delay_ms(200);
Led connected to PIN_A0 continuously blinking, (gabbarge data continuously coming in), when I click on any letter, there is no function.
related website is www.rentron.com/stamp_RF.htm
please help me out to send and receive data correctly. and why this gabbarge data comes, and how to eliminate them
thank you
PostPosted: Mon Nov 29, 2004 10:39 am     Reply with quote
there are some code in that website in Basic:
for transmitter:
symble dat=b2
symbol synch=b3
symbol junk=b4
synch="A"
junk=126
start:
pause 1000
for dat=1 to 255
  serout 0,N2400,(junk,synch,dat)
  pause 50
next
  serout 0,N2400, (junk,synch,0)
  goto start
for receiver
SYCH con "A"
BAUD CON 16780
DAT VAR byte
DIRH=%11111111
START:
SERIN 0, BAUD, [WAIT(SYNCH),DAT)
OUT=dat
GOTO start
how to explain them in CCS c language?
Mark
PostPosted: Mon Nov 29, 2004 11:12 am     Reply with quote
int dat;
char synch;
char junk;
junk = 126;
synch = 'A';
  for (dat=1; dat<=255;dat++)
    putc(junk);
    putc(synch);
    putc(dat);
    delay_ms(50);
  putc(junk);
  putc(synch);
  putc(0);
PostPosted: Mon Nov 29, 2004 11:32 am     Reply with quote
thank you Mark:
How about the serial in part?
Mark
PostPosted: Mon Nov 29, 2004 11:41 am     Reply with quote
It would be something like
char synch;
synch = 'A';
while (getc() != synch);
dat = getc();
or just
while (getc() != 'A');
dat = getc();
and then they just display the data on some port
PostPosted: Mon Nov 29, 2004 11:45 am     Reply with quote
can I use puts("126Adata\r") instead of put(126); put('A'); putc(data);
Mark
PostPosted: Mon Nov 29, 2004 11:48 am     Reply with quote
No
PostPosted: Mon Nov 29, 2004 11:52 am     Reply with quote
what if I want to sent some data like this"125 233 567 23"; instead of just one int data?
PostPosted: Mon Nov 29, 2004 12:26 pm     Reply with quote
Mark:
I test the program that you provided, I could not see any data being received, if I eliminate while (getc() != 'A'); I can see some data coming in , but the data is not right that I sent? why
Mark
putc(junk);
putc(synch);
putc(125);
putc(233);
putc(567);
putc(23);
Keep in mind the example they posted was a crude method for waking up the receiver and synching the data.
Mark
PostPosted: Mon Nov 29, 2004 12:30 pm     Reply with quote
I only translated the code for you. Post you whole program, both the receiver and transmitter code.
PostPosted: Mon Nov 29, 2004 12:46 pm     Reply with quote
Thank you mark:
here is the code for receiver:
#include <12F675.h>
#use rs232(baud=9600, parity=N, RCV=PIN_A3,XMIT=PIN_A2)
void main ()
  char ch[20];
  int dat;
     dat = getc();
     putc(dat);
transmitter:
#include <12F675.h>
void main ()
  char ch;
  int dat;
  char synch;
  char junk;
junk = 126;
synch = 'A';
    putc(junk);
    putc(synch);
    putc(dat);
    delay_ms(50);
  putc(junk);
  putc(synch);
  putc(0);
PostPosted: Mon Nov 29, 2004 12:50 pm     Reply with quote
here is some data I received from RF without while (getc() != 'A');
007³³“‘‘˙w³³“““‘w7“³“‘w·7³‘‘òw7³“‘‘ùv3³““‘Àw7³“““
“w³³³“‘÷w³““‘À6³““‘ w³³“‘‘w·³““‘àw·³““‘‘òw7““‘‘@ww·³““‘‘·7³“““‘‘˙w·³³“““ŝ|Lww7““‘wx`w7
³³‘‘ .
Mark
PostPosted: Mon Nov 29, 2004 12:51 pm     Reply with quote
Following their scheme it should have been:
Note that 567 requires 2 bytes
  int dat[5] = {125,233,55,2,23;
  for (i=0; i<5;i++)
    putc(junk);
    putc(synch);
    putc(dat[i]);
    delay_ms(50);
Mark
PostPosted: Mon Nov 29, 2004 12:56 pm     Reply with quote
The datasheet says the max rate is 3K BPS with the typ being 2.4K or 2400 BAUD
http://www.rentron.com/Files/rf.pdf
Also note that printing acsii 1-255 will give you some readable chars while others will do wierd things. You might want to change the range from 32 to 126.
Page 1 of 3
