MRF24j40 Control Frame
quijano930a
PostPosted: Sat Jan 28, 2017 11:39 am     Reply with quote
hi I'm using this module, and I'm trying to understand how i can implement the control frame. Now i have working a p2p and its working okay, but i don't know what are the parameters in the control frame. I have this structure in the write_tx_fifo, and if i try to implement ACK, the datasheet tells me to put the bit 5 as '1' to implement ack in the control frame.
So i have this code from Mikro c and i understand all parameter, less control frame. Here is the code.
void write_TX_normal_FIFO(void){
   int i = 0;
   data_TX_normal_FIFO[0]  = HEADER_LENGHT;
   data_TX_normal_FIFO[1]  = HEADER_LENGHT + DATA_LENGHT;
   data_TX_normal_FIFO[2]  = 0x01;                        // control frame
   data_TX_normal_FIFO[3]  = 0x88;
   data_TX_normal_FIFO[4]  = SEQ_NUMBER;                  // sequence number
   data_TX_normal_FIFO[5]  = PAN_ID_2[1];                 // destination pan
   data_TX_normal_FIFO[6]  = PAN_ID_2[0];
   data_TX_normal_FIFO[7]  = ADDRESS_short_2[0];          // destination address
   data_TX_normal_FIFO[8]  = ADDRESS_short_2[1];
   data_TX_normal_FIFO[9]  = PAN_ID_1[0];                 // source pan
   data_TX_normal_FIFO[10] = PAN_ID_1[1];
   data_TX_normal_FIFO[11] = ADDRESS_short_1[0];          // source address
   data_TX_normal_FIFO[12] = ADDRESS_short_1[1];
   data_TX_normal_FIFO[13] = DATA_TX[0];                  // data
   data_TX_normal_FIFO[14] = DATA_TX[1];
   data_TX_normal_FIFO[15] = DATA_TX[2];
   for(i = 0; i < (HEADER_LENGHT + DATA_LENGHT + 2); i++)
    write_ZIGBEE_long(address_TX_normal_FIFO + i, data_TX_normal_FIFO[i]); // write frame into normal FIFO
   set_ACK();
   set_not_encrypt();
   start_transmit();
I don't understand why control frame is set by these 2 parameters:
data_TX_normal_FIFO[2]  = 0x01;                        // control frame  data_TX_normal_FIFO[3]  = 0x88;
PostPosted: Sat Jan 28, 2017 12:07 pm     Reply with quote
If I hadn't seen this...
write_ZIGBEE_long
... I would not have known you were using Zigbee !
It's kinda CRITCAL to give as much information as possible when posting questions.
I suggest getting a GOOD manual on Zigbee, it's structure and commands. I have one buried 'somewhere' on another PC as I gave up on Zigbee duo to it's range limitation and huge overhead for sending data.
Zigbee like 99% of all communications(wireless or hard wired) is full of 'bloatware' not needed for 99% of the applications.
Jay
quijano930a
PostPosted: Sat Jan 28, 2017 12:11 pm     Reply with quote
I suppose if i put mrf24j40 the user will know where is my problem ::: but if he doesn't use the module he doesn't understand the question.
PostPosted: Mon Jan 30, 2017 6:20 am     Reply with quote
Please post where in the datasheet you read to put a 1 in bit 5 as there are a LOT of registers and modes this device has.
quijano930a
PostPosted: Mon Jan 30, 2017 12:10 pm     Reply with quote
hi
The MRF24J40 features hardware automatic Acknowledgment. It will automatically Acknowledge a frame if the received frame has the Acknowledgment request subfield in the frame control field set to ‘1’. This will maintain the RX-TX timing requirements of the IEEE 802.15.4 Specification.
Automatic Acknowledgment is enabled by clearing the NOACKRSP (RXMCR 0x00<5>) bit = 0. To disable automatic Acknowledgment, set the NOACKRSP (RXMCR 0x00<5>) bit = 1.
