ENC28j60 hostname or ip no
respected
PostPosted: Fri Jan 20, 2017 7:36 am     Reply with quote
Hi all,
   HttpClientSetHostNameROM((rom char*)"192.168.1.106");
   HttpClientSetUrlROM((rom char*)"/a.asp");
   HttpClientSetHostPort(80);
When i use ip number, command works but when i use hostname (www.mypage.com) doesn't work.
I want to use hostname. Does anybody have any idea?
PostPosted: Fri Jan 20, 2017 9:42 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=38023
The above thread says:
A connection could not be established with the remote host.
Check hostname and port settings. if using a hostname and
not an ip, then check that a valid DNS is configured.
Check that arp is able resolve the MAC address.
If the remote host is not on the local network, make sure that
gateway address is configured correctly.
