beginner question on interrupt ***Locked- C30/XC16 off topic
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion
littlewhitedot
PostPosted: Sun Jan 08, 2017 8:44 am     Reply with quote
Locked.
Reason: Microchip C30 and XC16 compilers are off-topic on CCS forum.
Use the Microchip PIC24 Topics forum:
http://www.microchip.com/forums/f179.aspx
- Forum Moderator
Hi all, i am using pic24fjgb002. I am trying out a simple interrupt code here but it does not seem to work.
#include "config.h"
void timer1_init(){
    //timer1 on, prescaler=64 (1Hz), select internal osc
    uint16_t mask = 0x8032;
    T1CON = (T1CON & ~mask)|(0x8020 & mask);
void interrupt_init(){
    INTCON1bits.NSTDIS = 1;     //disable nesting interrupt
    _T1IP = 0b001;              //timer1 priority 001
    _T1IE = 1;                  //enable timer1 interrupt
    IFS0bits.T1IF = 0;          //reset timer1 interrupt flag
int main(void) {
    interrupt_init();
    timer1_init();
    TRISAbits.TRISA0 = 0;   //A0 as output
    while(1){
void __attribute__((interrupt(auto_psv))) timer1_isr(void){
    if(IFS0bits.T1IF == 1){     //if timer1 flag = 1
        LATAbits.LATA0 ^= 1;
        IFS0bits.T1IF = 0;      //reset timer1 flag bit
For interrupt function, previously I have also try void interrupt timer1_isr, but it does not work. Can anyone help me out please?
PostPosted: Sun Jan 08, 2017 9:16 am     Reply with quote
Have you read the header of this forum?.
This forum is for _CCS C_.
Your code is not CCS C.....
PostPosted: Sun Jan 08, 2017 10:08 am     Reply with quote
Just 30 seconds LOOKING at that convuluted,confusing code made me soooo happy I chose CCS 25 years ago !
aside from no processor include those double underscored names scare me.
The CCS C equal of what is shown is clear, clean and EASY to understand !
Jay
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion All times are GMT - 6 Hours
