Multiplexing
naren
Multiplexing
PostPosted: Tue Nov 29, 2016 12:26 am     Reply with quote
Can anyone teach how to convert this c code to multiplexing since I used different ports for different 7 segment display.
#include <18f452.h>
#include <string.h>
#USE DELAY (CLOCK=4000000)
#FUSES XT, NOWDT, NOPROTECT, DEBUG
main(void)
int i=0,j=0;
set_tris_b(0xFF);
while(1){
start:if(input(PIN_C0)){   //PIN CO to start program
for(j=0;j<6;j++) {{{      //For the seven segment display for seconds
      output_a(0x3F);                                    //value 0
      delay_us(650);
      output_a(0x06);                  //value 1
      delay_us(650);
      output_a(0x5B);                  //value 2
      delay_us(650);
      output_a(0x4F);                  //value 3
      delay_us(650);
      output_a(0x66);                  //value 4
      delay_us(650);
      output_a(0x6D);                  //value 5
      delay_us(650);
      output_a(0x7D);                  //value 6
      delay_us(650);
      output_a(0x07);                  //value 7
      delay_us(650);
      output_a(0xFF);                  //value 8
      delay_us(650);
      output_a(0x67);                  //value 9
      delay_us (650);
   switch(j) {              //For the seven segment display for seconds
case 0 :output_d(0x06);
        output_a(0x3F);
case 1 :output_d(0x5B);
      output_a(0x3F);
case 2 :output_d(0x4F);
      output_a(0x3F);
case 3 :output_d(0x66);
      output_a(0x3F);
case 4 :output_d(0x6D);
        output_a(0x3F);
case 5 :output_d(0x3F);
      output_a(0x3F);
      if (j==5){                 //For the seven segment display for minutes
      i++;
         switch(i){
            case 1 :output_b(0x06);
            case 2 :output_b(0x5B);
            case 3 :output_b(0x4F);
            case 4 :output_b(0x66);
            case 5 :output_b(0x6D);
            case 6 :output_b(0x7D);
            case 7 :output_b(0x07);
            case 8 :output_b(0xFF);
            case 9 :output_b(0x67);
               i=-1;
            default: output_b(0x3F);
if (input(PIN_C1)){              //TO reset the stopwatch
      output_b (0x3F) ; //display will show a 0
      output_d (0x3F) ; //display will show a 0
      output_a (0x3F) ; //display will show a 0
           i=0;
           j=0;
      goto start;
naren
Mike Walne
Re: Multiplexing
PostPosted: Tue Nov 29, 2016 4:13 am     Reply with quote
Learn to use the code button, it preserves formatting and should make your code easier to read.
I don't understand your question.
Are you wanting to drive all your LED cathodes from one port and anodes from another?
If so there are loads of examples on this forum and CCS.
Mike
