Joined: 01 Jul 2010 Posts: 9269 Location: Greensville,Ontario
Posted: Sun Nov 20, 2016 4:09 pm |
CCS does supply an example 'stopwatch' program.maybe called ex_stwt.c in the examples folder...that would be a starting point.
You really need to supply us with your code and which PIC, qty of 7segment displays, etc.
Step one is to code/compile/run a '1 Hz LED' program to confirm you can get the PIC to do the basics......
then read, read, and read more....
