some code problems
Arsleosmithe
some code problems
PostPosted: Tue Nov 15, 2016 12:30 pm     Reply with quote
I'm having some problems understanding this MPPT code.
What are the exact input pins ? I don't get it.
Sorry I'm not a code expert.
#include <16f876.h>
#device *=16 ADC=10
#use delay(Clock=20000000)
#fuses XT, NOWDT, NOPROTECT, NOPUT, NOBROWNOUT,NOLVP
#define BATTERY_CHARGED 63
#define night_voltage 61
float mean_adc(byte channel) // Reads the adc port 30 times and gives the mean value
   int i,mean_total = 30;
   float mean = 0,mean1 = 0;
   set_adc_channel(channel);
   delay_us(100);
   for (i=1; i<=mean_total; i++)
      mean =mean + read_adc();
  delay_us(100);
   mean1=(mean/mean_total);
   return(mean1);
main()
   const byte current_channel = 0; // sets the channel one to read solar panel current
   const byte voltage_channel = 1; // set to read solar panel voltage
   const byte voltage_battery_channel=2;
   const byte current_battery_channel=4;// set to read battery voltage
   float current; // initialising variables
   float battery_voltage;
   float voltage;
   float power_new = 0.0;
   float power_old= 0.0;
   long duty_change = 1;
   long pwm_value;
   setup_adc_ports(ALL_ANALOG); // setting up all port a as analog
   setup_adc(adc_clock_div_32);
   setup_ccp1(CCP_PWM);
   setup_timer_2(T2_DIV_BY_1, 99, 1);// pwm frequency 50KHz
   set_pwm1_duty(60)
   while(TRUE) {
   current = mean_adc(current_channel);
   voltage = mean_adc(voltage_channel);
   battery_voltage=mean_adc(voltage_battery_channel);
   battery_current=mean_adc(current_battery_channel);
   power_new = current * voltage;
      if (battery_voltage > 517 || battery_current>670) // 517 corresponding to 14.4 battery voltage and 670 corresponding to 3A
        set_pwm1_duty(0);
         output_high(battery_charged);
      if (power_old >= power_new) {
         duty_change -= duty_change; // decrease duty cycle
       else if (power_old<power_new)
       duty_change += duty_change; // increase duty cycle
      power_old = power_new;
      pwm_value =pwm_value+ duty_change;
      if (pwm_value > 160)// maximum duty cycle
      pwm_value = 160;
         else if (pwm_value< 36)  // duty cycle minimum
         pwm_value = 36;
     if (voltage<429)//429 CORRESPONDING TO 12V
        pwm_value=0;
        out_high(night_voltage);
      set_pwm1_duty(pwm_value);
   } // end of while
}   //end main
PostPosted: Tue Nov 15, 2016 2:56 pm     Reply with quote
For the used input pins have a look at this code line:
Then, look in the manual for this function and you find:
Syntax: set_adc_channel (chan [,neg]))
Parameters: chan is the channel number to select. Channel numbers start at 0 and are labeled in the data sheet AN0, AN1. For devices with a differential ADC it sets the positive channel to use.
The channels are defined as:
Now lookup those pins in the datasheet for your chip. (AN0, AN1, AN2 and AN4)
I doubt this program was ever tested on real hardware...
The XT fuse only goes to 4MHz. For 20MHz it should be changed to HS.
PostPosted: Tue Nov 15, 2016 8:43 pm     Reply with quote
Another 'minor' detail NOT commented in the program is what value are the voltage divider resistors for the battery and solar panel voltages AND what are the current load resistors.
It's kinda IMPORTANT to have a schematic with this code !
Without it, the program will generate garbage and kill the batteries...
Jay
Arsleosmithe
PostPosted: Thu Nov 17, 2016 11:19 am     Reply with quote
Jay
Well thanks for the heads up... actually found the MPPT code on here.
I have a project on making a boost solar panel MPPT & I'm a power electrical engineer & have like zero programming skills... guess I'll be having LOTS of problems with the programming :(
Arsleosmithe
PostPosted: Thu Nov 17, 2016 11:21 am     Reply with quote
Thank you so much for the help..
And about the mode...will just changing the mode to HS solve the problem ?
PostPosted: Thu Nov 17, 2016 3:03 pm     Reply with quote
Potentially it'll solve that problem. However the error suggests the code is untested, which then tends to imply there may well be other faults....
PostPosted: Thu Nov 17, 2016 4:09 pm     Reply with quote
As with all PIC projects, you should code/compile and run a 1HZ LED program to confirm both hardware and software do function properly.
After that THEN code/compile your MPPT program.
Jay
