Joined: 08 Apr 2009 Posts: 100 Location: Chennai, India
timer0 and WDT (timer0 is too fast when WDT is enabled)
Posted: Thu Jan 19, 2017 3:07 am
Dear Board
I’m using 16F877A PIC and I'm facing this weird problem when enabling WDT.
First i wrote a code with timer0 which could create 10ms and executed.
- Code works fine and I get 10ms interval as expected
After I enabled WDT and used with approx. 2 sec (consulting close to 2 sec time in devices.h file) and restarted WDT every where possible in my code.
- After compiling and during execution I see the timer0 with 10ms is too fast and 10ms become to 40us. Too fast timer0 event occurring.
So weird.
When I disable WDT the timer0 restores to 10ms (good working).
Is there WDT and Timer0 somewhere linked or am I doing something wrong somewhere not known?
Please help me.
thank you
Posted: Thu Jan 19, 2017 3:26 am
Read the data sheet......
Yes on your chip, the WDT, and timer0, use a shared prescaler.
Look at:
"BLOCK DIAGRAM OF THE TIMER0/WDT PRESCALER".
The prescaler is only available or one device _or_ the other.
