CCS 5.015 did not find device PIC12 (L) F1571 / 2
le lam
PostPosted: Tue Jan 07, 2020 1:01 am     Reply with quote
Hi guy,
I am designing the application using PIC12(L)F1571/2, but no device found in CCS 5.015.
How can I program it with CCS.
Thanks!
PostPosted: Tue Jan 07, 2020 2:45 am     Reply with quote
Buy a newer compiler.
The 1571 came out at the end of 2013. Just postdates your compiler.
It was added just a couple of versions later (5.019 launched at
the start of 2014, has support for this).
PostPosted: Tue Jan 07, 2020 2:46 am     Reply with quote
You can download the CCS demo. It will be a current (or nearly current)
version of the compiler. It's the full compiler, except that it doesn't have
most of the example files. It will have the 12F1571 or 12F1572, but
the compiler will only work for 45 days after you install it. You need to
finish your project within that time.
See this link:
http://www.ccsinfo.com/ccsfreedemo.php
le lam
PostPosted: Tue Jan 07, 2020 3:12 am     Reply with quote
See this link:
I see, thank you so much!
le lam
PostPosted: Tue Jan 07, 2020 3:13 am     Reply with quote
Yes, thank you!
