CCS & MPLABX
ccsfred
CCS & MPLABX
PostPosted: Wed Jun 15, 2016 10:00 am     Reply with quote
I have been using CCS V4.078 & plugin with MPLAB 8.92 without problem, today I decided to upgrade to MPLABX. I installed MPLABX V3.3, then the plugin for MPLABX, which shows up in the installed tab in the plugins window, also in Tools > Options > Embedded > Build Tools & I can select CCS as my toolchain in project properties.
But when I try and build I get the following error:
CLEAN SUCCESSFUL (total time: 56ms)
make -f nbproject/Makefile-NewConfiguration.mk SUBPROJECTS= .build-conf
make[1]: *** No rule to make target '.build-conf'. Stop.
make[1]: Entering directory 'C:/temp/MPLAB_DSPIC/MOTOR.X'
make: *** [.build-impl] Error 2
make[1]: Leaving directory 'C:/temp/MPLAB_DSPIC/MOTOR.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUILD FAILED (exit value 2, total time: 53ms)
I've spent hours trying to overcome. I had problems trying to get CCS install with MPLAB, where it wanted to download a demo version, but after a few tries and adding to system variables it's now in MPLABX, just it looks like it still cant access it to build it. I've tried moving project to local C:\Temp .
Any ideas anyone please?
Thanks!
PostPosted: Wed Jun 15, 2016 10:03 am     Reply with quote
See near the end of this thread, and the link in it:
http://www.ccsinfo.com/forum/viewtopic.php?t=55236
http://ww1.microchip.com/downloads/en/DeviceDoc/MPLABX-v3.26-windows-installer.exe
ccsfred
PostPosted: Wed Jun 15, 2016 10:10 am     Reply with quote
OK Thanks, I'll trying rolling back! Let you know how i get on
