Madhu_k_r
RGB dot matrix |
Posted: Fri Jun 03, 2016 6:07 am |
hi..
Can i drive rgb dot matrix with pic ? If so can i get any circuit for the same
Thank you. _________________ KaalaayaTasmaiNamah: |
Posted: Fri Jun 03, 2016 7:23 am |
Show the matrix you want to drive. Show how you want to connect. Write some code. Nobody is going to do your homework from scratch........... |
Posted: Fri Jun 03, 2016 9:19 am |
ASMBOY is right , again !
We need more input !!
An 'RGB matrix' could anything from 3 LEDS( r,g,b) common cathode connected to say a 128 x 128 x RGB matrix.
Then there's 'minor' details like resolution,say 8 bit( 256 'steps' of colour), power requirements( 10ma per LED or 10 WATTS per LED), details, it's always details you need to tell us !
While the principles apply to all, it's 'in the details' as to HOW you implement the control code.
And of course what ELSE is the PIC supposed to do? Communicate with a PC? Auto change colours? Modify via Wireless ?
Details....
