pbraida
PIC 24EP512GU810 Bootloader problem |
Posted: Fri Jun 03, 2016 5:22 am |
First sorry for the bad English.
My compiler version is 5.059.
I am try to use the example: pcd_aux_bootloader.
My board has a PIC24EP512GU810 like the example, the bootloader works well. The firmware download occurs with no errors. The problem is when the board re-boots, it never enters in the application program, and if I press the button the bootloader starts again.
I use the example with no notification, the only one is the com port I use is UART2.
Thanks for any help. |
pbraida
Posted: Fri Jun 03, 2016 8:06 am |
This is the code for bootloader:
#define ROM_WRITE_CAN_MODIFY_CONFIG_BITS
#include <24EP512GU810.h>
#fuses NOWDT,RESET_AUX //The RESET_AUX fuse causes PIC to reset into Auxiliary Memory
#build (AUX_MEMORY) //Build code for Auxiliary Memory
#use delay(clock=120MHz,crystal=8MHz)
#pin_select U2TX=PIN_E2
#pin_select U2RX=PIN_E3
#use rs232(baud=9600,UART2,errors)
#define PUSH_BUTTON PIN_B9
#define LED1 PIN_A0
#define LED2 PIN_A1
//The following defines are necessary to use PCD's serial bootloader, loader_pcd.c.
#define _bootloader
#define LOADER_SIZE 0
#define APPLICATION_START 0
#define APPLICATION_END getenv("PROGRAM_MEMORY")
//Include PCD's serial bootloader
#include <loader_pcd.c>
#INT_AUX
void auxialary_isr(void)
if(interrupt_enabled(INT_TIMER1) && interrupt_active(INT_TIMER1))
output_toggle(LED1);
clear_interrupt(INT_TIMER1);
if(interrupt_enabled(INT_TIMER2) && interrupt_active(INT_TIMER2))
output_toggle(LED2);
clear_interrupt(INT_TIMER2);
set_pullup(TRUE,PIN_B9); // BOTAO 1
set_pullup(TRUE,PIN_B10); // BOTAO 2
set_pullup(TRUE,PIN_B11); // BOTAO 3
if(!input(PUSH_BUTTON))
delay_ms(140); // wait for PLL
printf("\r\nBootloader Version 1.0\r\n");
// Let the user know it is ready to accept a download
printf("\r\nWaiting for download...");
setup_timer1(TMR_INTERNAL | TMR_DIV_BY_256, 58593); //~250 ms period
setup_timer2(TMR_INTERNAL | TMR_DIV_BY_256, 23437); //~100 ms period
//! enable_interrupts(INT_TIMER2);
// Load the program
load_program();
goto_address(APPLICATION_START);
This is the app code:
#use delay(clock=120MHz, crystal=8MHz)
#define PUSH_BUTTON PIN_D6
#define LED1 PIN_A0
#define LED2 PIN_A1
#define LED3 PIN_A2
rom char version[] = "Application Version 1.0";
void DisplayLeds(unsigned int8 Led)
output_low(LED1);
output_low(LED2);
output_low(LED3);
switch(Led)
case 0:
output_high(LED1);
case 1:
output_high(LED2);
case 2:
output_high(LED3);
#INT_TIMER1
void led_isr(void)
static unsigned int8 Led = 0;
DisplayLeds(Led);
if(++Led >= 3)
Led = 0;
printf("\r\n%s\r\n", version);
printf("You can put whatever code you want here.\r\n");
printf("So enjoy!\r\n");
setup_timer1(TMR_INTERNAL | TMR_DIV_BY_256, 46874); //200 ms period;
restart_wdt();
Any ideas, this code is a CCS example the only change to the original one is the UART number.
Thanks. |
