odt133
printf print broken message |
Posted: Fri May 27, 2016 2:55 am |
Could anybody tell me what I did wrong?
I'm trying to use printf(). but not working properly.
Source code is like this.
Code: | #include "C:\Program Files (x86)\picc\devices\18F6520.h"
#use delay(clock=40000000)
#USE RS232(uart1, baud=9600, bits=8, parity=n)
#fuses H4,OSCSEN,BROWNOUT,BORV27,NOWDT,NOPROTECT,CCP2E7//config set1
void main( void )
while( true )
printf("led on.\r\n");
output_high( pin_f7 );
printf("led off.\r\n");
output_low( pin_f7 );
and result from Tera Term is like this.
Code: | ?幢
슊+?幢
+?幢
슊+?幢
As you see, character is broken. I set tera term's baudrate as 9600.
What did I wrong? Please,,
Thank you in advance. |
kWoody_uk
Joined: 29 Jan 2015 Posts: 47 Location: United Kingdom
Posted: Fri May 27, 2016 4:04 am |
Check the basics:-
Is the LED flashing at the correct rate?
Keith |
RF_Developer
Posted: Fri May 27, 2016 4:47 am |
kWoody_uk wrote: |
Almost certainly not. The order of things is not right. Should be device.h, fuses, delay, then rs232 and the like (timers etc), then do user code.
Code: | #include <18F6520.h> // Use <> and select the right path in the project.
// Fuses MUST come before delay and use rs232, and they must come after the processor include. I have not checked these fuses are sensible.
// Use rs232 must come after use delay.
// Then other stuff.
Posted: Fri May 27, 2016 11:06 am |
also there needs to be a 'MAX232', TTL<>USB' or similar interface between PIC and PC.
Posted: Fri May 27, 2016 11:27 am |
and (of course) to give 40MHz, the crystal needs to be 10MHz. Back to 'does the LED flash at the correct rate'. |
