PIN_B2 in PIC12F508 is not toggling
Madhu_k_r
PostPosted: Wed Apr 13, 2016 3:14 am     Reply with quote
Hi...
I have used pic12f508 for one of my project but pin_b2 and pin_b3 are not going high nor low but other i/o's are working fine.
My code:
#include <suction_12f508.h>
#define START_STOP  PIN_B1
#define SENSOR      PIN_B0
#define MOTOR       PIN_B5
#define SOLENOID    PIN_B4
#define BUZZER      PIN_B2
int8 SOLENOID_ON=0;
int16 i=0;
int8 M_ON=0;
int16 delay=0;
   //Switch OFF MOTOR & SOLENOID TRIACs
   output_high(MOTOR);
   output_high(SOLENOID);
      output_high(BUZZER);
      output_low(BUZZER);
#include <12F508.h>
#FUSES INTRC                    //Internal RC Osc
#FUSES PROTECT                  //Code not protected from reading
#FUSES NOMCLR                   //Master Clear pin enabled
#use delay(int=4000000)
thanks in advance.
KaalaayaTasmaiNamah:
PostPosted: Wed Apr 13, 2016 5:12 am     Reply with quote
I see GP2 is used to control a 'buzzer'. To me a 'buzzer' is an EN device needing a lot of current and cannot be driven from a PIC I/O pin. Please try an LED and 470r on GP2 and see if it functions properly. If the LED doesn't flash odds are you've damaged the PIC by trying to draw too much current using the 'buzzer'.
GP3 can ONLY be used as an INPUT not as an output. Please read the datasheet again, page 13. Little PICs are fun BUT you can quickly run out of pins ! You may be able to use GP3 for the 'sensor', and then GP0 for the output.
Also, you should NOT enable the Fuse 'Protect' unless you're actually selling the product and this is the final program for the PIC. There is no need to 'protect' the PIC until then. I don't even bother with client's PICs,not really necessary.
Jay
PostPosted: Wed Apr 13, 2016 9:09 am     Reply with quote
For PIN_B2, see this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=53002
