Do I manually must set RCON register or the compiler do it?
E_Blue
PostPosted: Thu Apr 07, 2016 8:39 am     Reply with quote
My first code line inside Main is
LastRestart=RESTART_CAUSE();
µC is PIC18F67J50, Compiler version is 5.048.
Electric Blue
asmboy
PostPosted: Thu Apr 07, 2016 9:21 am     Reply with quote
the answer is in the datasheet
go back and READ section
4.1 RCON Register
and your question will be answered.
learn too make the datasheet your primary source and much time will be saved.
E_Blue
PostPosted: Thu Apr 07, 2016 9:46 am     Reply with quote
I already did it, the datasheet say yes; but since the compiler has some automated function I don't wanna do something that is already handled by the compiler and maybe cause some interference on the program behavior.
Electric Blue
asmboy
PostPosted: Thu Apr 07, 2016 11:06 am     Reply with quote
look at the .LST file your program generates -
then find any reference to the RCON register address in the listing
to see what the compiler does
PostPosted: Thu Apr 07, 2016 11:07 am     Reply with quote
Restart-cause does everything. It reads the register, and updates it.
But _big caveat_ some bits in the register change when other things are configured, so restart_cause must be called before any major configuration changes after boot, otherwise the value may be invalid.
