I'm building a propeller clock, for this i want to add into my code (once i have it ) a function that receives an argument (A-Z or 0-9) and send the data through PORTB.
Example:
SYMB(C); //Where SYMB is my function or subroutine
SYMB(C);
SYMB(S);
char SYMB(){
switch SYMB
case C:
PORTB=XXX;
case s:
PORTB=XXX;
Or something like this
Any ideas?
newguy
Posted: Sat Mar 26, 2016 1:14 pm
Almost.
void SYMB(char c) {
switch (c):
case 'C':
...do something
case 's':
...do something else
Posted: Sat Mar 26, 2016 1:20 pm
void symb(char val)
{ //you were saying that the function returned a character
//not that it accepted a character
switch (val)
case 'C': //This is the character 'C'
output_b(xxxx);
case 's': //The character 's'
output_b(yyyy);
Generally in C, use the standard that ALL CAPITALS is a #define.
